Forums Migration
Please read this thread
How to tell what engine mount is gone.
by mossietheno1 - 07/10/20 04:28 AM
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
Castrol Euro at Walmart, but which one?
by Impatient - 07/10/20 12:48 AM
Car Stereo Upgrade
by montero1 - 07/09/20 11:55 PM
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
How bad is it?
by Averroes - 07/09/20 05:29 PM
various vintage oil filters cut apart
by dogememe - 07/09/20 05:26 PM
LCD burn in? Seriously?
by Klutch9 - 07/09/20 04:12 PM
907Lynette, mckaskie, mkid, kuldeep, BillDros
71900 Registered Users
37 registered members (bullwinkle, chunt, bbhero, dieselguy67, 6 invisible), 782 guests, and 29 spiders.
Topics307,673
Posts5,315,373
Members71,900
Air Compressor OCI? #5162860 07/16/19 07:35 PM
V
Vern_in_IL Offline OP
V
Every time I change the oil, there are always tons of metal flakes coming out.... (standard 5hp 20 gallon portable)
Now I know many people that change compressor oil maybe once in ten years or longer....
The last oil change I switched to a "synthetic compressor oil" by Milton, for cold weather performance.
How often should I be changing this oil?
Re: Air Compressor OCI? [Re: Vern_in_IL] #5162875 07/16/19 07:51 PM
J
JC1 Offline
J
How long have you had the compressor? How many hours of use before you change the oil?
Maybe you should use this for a few short OCI on it. https://www.harborfreight.com/32-fl-oz-compressor-oil-68097.html
I personally would be using that HF oil if I was in your shoes and see if it clears up the metal bits inside the motor.
I just bought a used Sanborn 60 Gallon air compressor. Changed the oil with a Rolair semi-synthetic. Didn't see any bits of metal in the used oil, but my eyesight isn't the greatest these days.
https://www.princessauto.com/en/detail/1-litre-synthetic-blend-air-compressor-pump-oil/A-p8436784e
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Air Compressor OCI? [Re: Vern_in_IL] #5162883 07/16/19 07:56 PM
V
V
I've had the compressor since 1997. CH "FarmHand" I usually change the oil after 10 hours, it gets used about 1 hour per year.
Re: Air Compressor OCI? [Re: Vern_in_IL] #5162895 07/16/19 08:01 PM
J
JC1 Offline
J
That's pretty low usage. I don't think I'd wait ten years to change it. Buy that oil from HF, it's 6.99. Use the 25% off coupon it's $5.25.
Change it once a year. I'm thinking I'll do the same for mine a few times before winter sets in. I use my compressor every few days. How often do you drain the water from the tank?
Re: Air Compressor OCI? [Re: JC1] #5162934 07/16/19 08:57 PM
Chris142 Offline
I drain my tank of water every time i use it. I dont usually get much out though. I put amsoil in mine and have not changed it since.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Air Compressor OCI? [Re: Chris142] #5162940 07/16/19 09:05 PM
J
JC1 Offline
J
I do that too. I installed a ball valve on mine. What I do now is crack the valve open for 1 second a good blast of water comes out with the air.
The previous compressor I bought the guy never drained it. It had close to 2 liters of water inside over the years and it was a brown as gravy.
Re: Air Compressor OCI? [Re: Vern_in_IL] #5162973 07/16/19 09:51 PM
clinebarger Offline
I change mine once a year no matter what. I can't picture a 5 horse motor on a 20 gallon compressor?
2001 Chevy Camaro L92/4L80E
Re: Air Compressor OCI? [Re: clinebarger] #5163008 07/16/19 11:14 PM
U
user52165 Offline
U
It would be interesting to see the motor specs on that unit. 5hp would require 220v and about 15 - 20 amps. Well, that's for a real 5hp motor.
I doubt his is.
CH Campbell Hausfeld? They are low on my list.
Re: Air Compressor OCI? [Re: Vern_in_IL] #5163056 07/17/19 01:51 AM
G
Gasbuggy Offline
G
Every 2 years.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Air Compressor OCI? [Re: Vern_in_IL] #5163198 07/17/19 07:56 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Every 10 years here. I've had mine 40 years.
Re: Air Compressor OCI? [Re: Vern_in_IL] #5163389 07/17/19 11:51 AM
circuitsmith Offline
I rub a little between the fingers. When it feels less slippery or a bit gritty I change it. 10+ years.
Re water drain I do it after every substantial use in the summer. I've learned it collects virtually none in the winter.
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: Air Compressor OCI? [Re: Vern_in_IL] #5163397 07/17/19 12:04 PM
A
A_Spruce Offline
A
I've only changed the oil a couple of times in my compressor in the nearly 30 years I've had it. It's a compact portable Superior, which I was told at the time was an Italian made compressor. Don't know, don't care, the thing has seen extreme use and working conditions, and other than a little dirt and wear, it runs like new. The only problems I've had with it is having to replace the shut-off switch twice. I try to keep the tanks drained, but for some reason that gets neglected frequently. I don't use it as much or heavily any more, but in my construction days, it was used almost daily for everything from installing trim to framing houses to blowing drywall texture.
Oil still looks great, smells great, and is less filling . . . no wait, that's not it LOL feels great, no grit, no issues.
'03 Suburban
