Forums Migration
Please read this thread
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
Castrol Euro at Walmart, but which one?
by Impatient - 07/10/20 12:48 AM
Car Stereo Upgrade
by montero1 - 07/09/20 11:55 PM
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
How bad is it?
by Averroes - 07/09/20 05:29 PM
various vintage oil filters cut apart
by dogememe - 07/09/20 05:26 PM
LCD burn in? Seriously?
by Klutch9 - 07/09/20 04:12 PM
WTB - 1050 video card
by stockrex - 07/09/20 02:28 PM
907Lynette, mckaskie, mkid, kuldeep, BillDros
71900 Registered Users
22 registered members (Char Baby, afree, bbhero, Driz, Bjornviken, eljefino, 2 invisible), 681 guests, and 46 spiders.
Topics307,672
Posts5,315,366
Members71,900
80% Furnace exhaust silencer? #5162767 07/16/19 05:10 PM
P
PandaBear Offline OP
P
You probably heard about my noisy furnace (Rheem Criterion II, 100K BTU, 4 burner, with a 3 ton Carrier AC) that vent through the wall between 2 bedrooms. It was throttling for about 1 min every 15 mins because it is over powered, waking people up at night, and drying the air when it is on.
I've replaced the exhaust draft fan and it helped the noise problem a lot (probably at least 10-20 dB), but it is still a bit noisy and it is still very dry. So, I'm thinking about replacing it to quiet down and make it more comfortable. I'll never make the money back in terms of efficiency, but at least I can sleep better.
Here are the 2 approaches I can think of:
1) A new 90%+ that vent to the side of the house, the new exhaust would be the expensive part, the furnace is probably going to be just a cheap 40k BTU 1200CFM dual stage Goodman. I won't be able to do anything and will like hire a pro. I'm guessing it would be a $4k-5k job consider how expensive labor is here.
2) A new 80% 40K BTU 1200CFM dual stage Goodman. I might be able to swap it out myself but I do need to make an adapter (i.e. cabinet width going from 19" to 14") between the furnace and the existing inlet and outlet. I should be able to just dip switch my way to hard wire it to 32K BTU and max airflow. The exhaust draft motor is still blowing through between the wall, so there'll still be noise, but the 66% reduction in heat will likely make it more comfortable and throttle a lot less. If exhaust vent muffler exist, I'd like to install one before it reaches the bedroom. So far I see a lot of these thing on pot growing hobby site but I'm wondering if there are furnace specific muffler instead. The furnace, adapter, and exhaust will likely cost $1k for parts, and I might be able to install them myself.
Suggestion?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162808 07/16/19 06:07 PM
CDX825 Offline
Going from 100k btu to 40k btu is a big drop. I don't know your square footage but I would suggest a 60k or 80k two stage.
Also stay away from Goodman. I do HVAC work for a living and hate goodman with a passion. Their equipment is junk!
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162832 07/16/19 07:04 PM
R
RF Overlord Offline
R
I can't help with your issue, but I am curious. What do you mean by throttling? I've never heard that term used with heating equipment before.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162854 07/16/19 07:29 PM
I
irad Offline
I
For drying you can add a humidifier or place trays of water at the output vents. If the noise is at start and stop it might be duct flexing. Find the ducts that flex and add L brackets/bracing to stop the flexing duct. If it is motor noise add noise baffling around furnace, but not touching furnace.
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162862 07/16/19 07:38 PM
P
P
The big jump is the intend. The house was build initially with a way over powered furnace (demo home, probably need to warm up fast in the morning to demo). It basically kicks in for 1 min and then turn off for 15 mins. That 1 minutes is very uncomfortable dry heat. We usually turn on the furnace when it is about 58F inside, and set the thermostat at 64F.
I thought the 1 on 15 off is called throttling, I guess I was using the wrong word (maybe it is short cycling?).
The sound is actually air flow within the flue / exhaust. It is within a thin wall so there's not much I can do to slow it down. Maybe going from 100k BTU to 32k / 40k would help.
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162897 07/16/19 08:05 PM
J
JC1 Offline
J
Is there any way to soundproof the walls around the furnace? I would try to use some Roxul insulation (Mineral Wool - Safe and sound) to kill the noise.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 80% Furnace exhaust silencer? [Re: JC1] #5162924 07/16/19 08:39 PM
P
P
Unfortunately no, the vent is a flat vent (adapter on both in the garage and the attic) in the wall and it is almost touching the drywall already.
Come to think of it, maybe a sophisticated muffler to slow the air down, then split from 1 vent to 2 inside the wall (to slow down the air flow) then merge back into 1 and go out of the roof, would be a solution. Then again, if I were to spend so much effort, I'd rather just replace the whole furnace with a side vent 90+.
The sqft is 1454, but it has a cathedral ceiling in the living room so the "volume" of air to heat is about 400 sqft more had it been the same house in 2F all over.
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5162989 07/16/19 10:25 PM
AZjeff Offline
Would it be possible to bleed off some of the heated air to outside by disconnecting a duct and running it out a vent? Kind of bogus but it would lengthen the heat cycle and effectively lower the BTU of the furnace. Any way to shut of some of the burners?
Doesn' fix the noise but might help the short cycling.
Probably the safe way to slow the velocity of the exhaust gas is to open the wall and put in a flue with much larger volume, like your 2 pipe idea.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 80% Furnace exhaust silencer? [Re: AZjeff] #5163070 07/17/19 03:23 AM
P
P
The duct flow is not what's noisy, or I'd complain about AC in the summer too.
If I am going to bleed the exhaust to the side of the wall, I would just do it right by going 90+. Side venting a 80% furnace is bad for your wall (heat) and you still need permit and all sorts of other works, so why bother?
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5163106 07/17/19 05:55 AM
AZjeff Offline
No, bleed off heated room air so house doesn't heat up as fast. You'd need make up air from outside so not as simple .
Still think if you could cut the burners in half you could put in a much lower CFM draft fan and lower exhaust velocity that way.
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5163313 07/17/19 09:59 AM
K
KrisZ Offline
K
The air handler speed can be varied on the control board a little bit. I would check it out and see if you can set it on the lowest possible setting. That would be my first step, since it doesn't require any money.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5163439 07/17/19 01:10 PM
P
P
Plugging 1 or 2 of the 4 burners may be an idea (at least if it crack after a couple years it will be worth the money already), and then reducing the exhaust draft fan speed (instead of the blower speed I assume)? That'll be a completely new draft motor I guess?
Re: 80% Furnace exhaust silencer? [Re: PandaBear] #5163517 07/17/19 02:42 PM
J
JustinH Offline
J
New 80 percent furnace 40k is probably 600 bucks. I'd go that route before messing with an old 100k unit. Not sure if 80 percent is still legal in California.
'16 Ford Escape
'11 Scion XB
Re: 80% Furnace exhaust silencer? [Re: JustinH] #5163900 07/17/19 10:28 PM
AZjeff Offline
I'd mess with the old one a bit just to see if it could be done safely. Then probably change it out.
Re: 80% Furnace exhaust silencer? [Re: JustinH] #5164160 07/18/19 09:48 AM
W
wag123 Offline
W
80% is still allowed for retrofits in California. 92% is required for new construction.
