Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
23 registered members (avi1777, bachman, deanm11, Char Baby, dieselguy67, bernau, 2 invisible), 1,093 guests, and 19 spiders.
Topics301,733
Posts5,201,592
Members70,763
Determining if car battery has much life left #5162641 07/16/19 01:47 PM
paulri Offline OP
I have put my cars on a 33-36 month preemptive replacement schedule (I find they conk out at that time). I have a new to me Highlander that has been parked in a garage (my cars are outside 24/7), and so far, has had 4-5 years on batteries (car has been in the same area as I live in). The three year anniversary of its replacement is Oct 2019. The cheapo in me wants to try to squeeze as many more months out of the battery as I can get. The impatient part of me that hates it when I have to call a tow truck, wants to replace it now.
I called my local WM TLE and I was told that I can bring the car in, and that it would take about an hour or so, but they can test the battery to see how much life is left in it. Is this a reliable test? Is there in fact a reliable test for how much charge is left in the car battery (I'm talking about the 12v, not the hybrid traction).
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Determining if car battery has much life left [Re: paulri] #5162651 07/16/19 01:53 PM
M
mk378 Offline
M
Hybrids probably don't make a lot of demand on the 12 volt battery. As long as there is charge in the traction battery that is what starts the engine.
The standard test for car batteries is the load tester. It draws 200 or 300 amps from the battery to simulate a conventional car starting, and watches how low the voltage goes. The test itself takes less than a minute. Most of the 1 hour at Walmart will be waiting.
Re: Determining if car battery has much life left [Re: paulri] #5162654 07/16/19 01:58 PM
J
JMJNet Offline
J
You can DIY, just get a battery load tester from HF for under $20.
It is an analog type, you can do the test every month to see a trend if it is trending to go bad.
Instead of waiting for 1 hour everytime at Wally.
  • 2017 Toyota Sienna
Re: Determining if car battery has much life left [Re: paulri] #5162655 07/16/19 01:59 PM
H
hallstevenson Offline
H
I think the test they do is a "load" test, which tells you how strong it is, i.e. for starting the car. It can't predict the remaining life of a battery though.
Re: Determining if car battery has much life left [Re: paulri] #5162660 07/16/19 02:02 PM
Donald Offline
A conductive test will tell you how much CCA is currently in the battery and the label says how much when new. Its pretty reliable. They probably have a Midtronics tester. Hopefully it takes into account battery temp.
You can buy lower end versions of these testers for $40 to $60.
A temp compensated load test using 1/2 CCA for 15 seconds and check voltage at the 15 second mark is better but few places use this as the battery has to be fully charged.
2015 Ford F-250 w/Powerstroke
Re: Determining if car battery has much life left [Re: paulri] #5162681 07/16/19 02:21 PM
spavel6 Offline
Might be worth investing in a jump-n-carry (https://www.amazon.com/Clore-Automotive-Jump-N-Carry-JNC660-Starter/dp/B000JFJLP6) and not replace batteries earlier than they need to be. I've found that good batteries last 6+ years without an issue. It seems that 36 months and throw-away is a bit wasteful and uneconomical..
My unit can jump start a completely dead VW diesel, so I'm sure a Toyota would be no problem. Then when/if the battery dies, you can jump it and replace it without calling a tow truck. Plus added protection in case you leave the lights on overnight smile
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Determining if car battery has much life left [Re: paulri] #5162695 07/16/19 02:44 PM
G
Gebo Offline
G
Get your own load tester. Great $40 or so investment.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Determining if car battery has much life left [Re: spavel6] #5162701 07/16/19 02:53 PM
paulri Offline OP
Given that my batteries for years have died just before or just after 36 months, this isn't a number I just picked randomly. I'd rather drive to a store and get a new battery on my time, than have to call a tow truck, and hope my family doesn't need our other car that day when I want to go somewhere.
Re: Determining if car battery has much life left [Re: paulri] #5162706 07/16/19 03:02 PM
E
eljefino Offline
E
Where does the Highlander keep its 12v battery? If not underhood, there might be less heat-related stress.
The Prius community has jump started a dead 12v system with a Dewalt drill battery and other lightweight aids.
Re: Determining if car battery has much life left [Re: eljefino] #5162709 07/16/19 03:04 PM
paulri Offline OP
It is under the hood. I think what helped keep it from the heat cycles was that it was stored in a garage that stayed reasonably cool (for a garage in the desert). But now that I own it and store it outside, the battery should suffer more heat/cold cycles.
Re: Determining if car battery has much life left [Re: paulri] #5162716 07/16/19 03:09 PM
E
edwardh1 Offline
E
who drives this car, and in what conditions - Darkness, cold lonely roads, bad crime areas ?
I like3 year changeouts
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Determining if car battery has much life left [Re: edwardh1] #5162720 07/16/19 03:17 PM
paulri Offline OP
desert region. exurb area, not lonely roads, no bad crime areas that I drive through. Plus I do have a cell that I keep charged 99% of the time.
Re: Determining if car battery has much life left [Re: paulri] #5162731 07/16/19 03:33 PM
Z
zvm77us Offline
Z
Re: Determining if car battery has much life left [Re: paulri] #5162769 07/16/19 04:14 PM
paulri Offline OP
For those recommending that I get a load tester--here is one @ HF for $20. $20 sounds like it could easily pay its way for me with a few months extra use of a battery, as well as still let me know that the battery has enough power for me to drive to WM to get my next one. The ratings are pretty high, 4.5/5 stars from over 500 reviewers.
I take it that this isn't so cheap that it would fall apart, or give me inaccurate readings?
Re: Determining if car battery has much life left [Re: spavel6] #5162776 07/16/19 04:28 PM
M
maxdustington Offline
M
If OP does not need to jump cars all the time a lithium jump pack will be sufficient and much cheaper than a JNC. I just bought one for $90 CAD and it went on sale for 33% off on prime day.
99 Toyota Tercel CE 5EFE/C151
