Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
25 registered members (Char Baby, Arrechera, bmod305, Dave_Mark, alcyon, boostedtsiawd, 3 invisible), 960 guests, and 18 spiders.
Topics301,733
Posts5,201,567
Members70,763
Rear Diff Seal Leak? #5162621 07/16/19 01:31 PM
P
Pike51 Offline OP
P
I have a very minor leak at the rear diff seal. Anyone have thoughts on just adding some stop leak like Blue Devil? The fluid is fairly new.
1951 Chevy pickup 350/700r4
2015 Chevrolet Suburban LTZ 4x4
Re: Rear Diff Seal Leak? [Re: Pike51] #5162627 07/16/19 01:35 PM
R
RamFan Offline
R
I doubt the stop leak would work. Gravity is not your friend when it comes to a rear diff leak. Better to pop the cover off and reseal. If the fluid is new, there's nothing wrong with using it again.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 24k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 68k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Rear Diff Seal Leak? [Re: Pike51] #5162734 07/16/19 03:39 PM
L
Lubener Offline
L
Leave it and top off as needed. I would not mess with a minor leak at the pinion seal, only if oil is leaking out an axle seal onto your brakes. An additive likely will not work but you got nothing to lose by trying..
The "thinking" man's friend.
Re: Rear Diff Seal Leak? [Re: Pike51] #5162864 07/16/19 06:41 PM
A
andyd Offline
A
Lubener X2 grin2
Thick oil is better grin2
Re: Rear Diff Seal Leak? [Re: Pike51] #5163266 07/17/19 08:05 AM
Snagglefoot Offline
Where’s the leak? The OP said “rear diff seal”. At the pinion, or the cover plate.
If you want the job done right......do it yourself.
Re: Rear Diff Seal Leak? [Re: Snagglefoot] #5163348 07/17/19 09:43 AM
bdcardinal Offline
Exactly, pinion, axle/hub, or cover?
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Rear Diff Seal Leak? [Re: Pike51] #5163391 07/17/19 10:54 AM
P
Pike51 Offline OP
P
Sorry... at the pinion.
Re: Rear Diff Seal Leak? [Re: Pike51] #5163396 07/17/19 11:02 AM
Snagglefoot Offline
Which vehicle and rear end is it. Perhaps someone can shed some light on how difficult it would be to chance the seal. smile
Re: Rear Diff Seal Leak? [Re: Pike51] #5163572 07/17/19 02:39 PM
R
RamFan Offline
R
Ohh, that changes things a bit. I thought you meant at the plate.
You state the leak is very minor. How many drops a day are we talking?
Re: Rear Diff Seal Leak? [Re: Pike51] #5163998 07/18/19 04:33 AM
L
Lubener Offline
L
I had the dealer under extended warranty, replace the pinion seal for a minor leak. I wish i had left it alone. I once had a quiet differential, after their repair the differential had a whine because they got the preload screwed up. It was a PITA dealing with them afterward and getting it straightened out..
My truck has a minor pinion leak, it has been leaking for over twenty years. I had to top off once during that time. Like I said, unless it is leaving a large spot on the driveway overnight, I would leave it alone. You may never have to top it off.
Re: Rear Diff Seal Leak? [Re: Pike51] #5168119 07/22/19 12:56 PM
P
Pike51 Offline OP
P
This is the rear end on my 51 Chevy... it was pulled from a 1969 Buick LeSabre.
Minor as in just seeps and I can wipe fluid away when it's on the lift... sounds like I may just leave it alone.
