Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
31 registered members (Bailes1992, CB900F2, Bookmaker, Char Baby, bachman, ChrisD46, 5 invisible), 826 guests, and 17 spiders.
Topics302,027
Posts5,207,498
Members70,819
Keeping downspouts clean #5162512 07/16/19 12:00 PM
K
Klutch9 Offline OP
K
I’m having a nightmare of a time keeping my downspouts clean. House is 20’x40’, gable roof, 4 or 5/12 pitch, one gutter on each 40’ side. I have 3 massive trees that tower over the house, so the gutters and spouts get cleaned regularly. The gutters actually stay pretty clean, but the spouts clog every week or two. If there is a hard rain, it just starts spilling over the edge. The house had the perforated gutter screens which actually made things worse. My issue is that they clog with buds from the maple tree and/or leaves, to the point where water won’t even enter the gutters, so I removed them. I’ve considered adding an extra spout on each side, about halfway down. Gutter sloping is correct, but this would help alleviate congestion on each spout. Are there any screens o could add that actually help?
'11 Fusion SE 2.5L - 89k miles - HK 0w20 syn, Carquest Blue filter
'08 Sedona LX LWB 3.8L - 141k miles - Havoline HM 5w20, Carquest Red filter
Re: Keeping downspouts clean [Re: Klutch9] #5162518 07/16/19 12:05 PM
PimTac Offline
Perhaps this design will be better than the screens in your environment.
https://www.leafguardgutters.com/
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Keeping downspouts clean [Re: PimTac] #5162526 07/16/19 12:16 PM
V
Virtus_Probi Offline
V
We have gutters similar to this design, not quite the same, and they work great!
We have a monster pine looming over part of the house that will either need to come down or be scaled back dramatically at some point as well as multiple tall oaks, maples, beeches, hemlocks, etc., all around the house...and have never had a gutter clog.
The only issue we have had is that our gutters actually fit partway under the shingles and the contractor squawked a bit when we had our roof redone...but, he also told us that gutters of this type were extraordinarily common around us and everybody seemed to love them, so he had taught his crew how to deal with them.
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Keeping downspouts clean [Re: Klutch9] #5162529 07/16/19 12:19 PM
doitmyself Offline
Anything you try will have to stand up to the rigors of our winters (ice [censored], etc.). https://www.icedamremovalguys.com/learning-center/how-gutter-guards-make-ice-dams-tougher-to-remove/
Maybe installing larger downspouts might help?
I'm thinking the only real answer is to come up with an easy way to regularly clean out the gutters. Maybe some kind of wand on a hose. https://www.amazon.com/Orbit-58543-Telescoping-Cleaning-Ratcheting/dp/B00CLOG5MK
Re: Keeping downspouts clean [Re: doitmyself] #5162536 07/16/19 12:22 PM
K
Klutch9 Offline OP
K
I was considering trying the foam mesh type, even if only on half of each side (the side where the trees hang over, and coincidentally where the downspouts are). They will clog over time I’m sure, but they have much more surface area for water to come through as opposed to the perforated type.
Re: Keeping downspouts clean [Re: Klutch9] #5162537 07/16/19 12:24 PM
F
Fawteen Offline
F
Leaftek gutter covers. I've had them on our house for about 10 years, and not a single problem and very easy to install. They didn't have any problems even during hurricane Michael. We have lots of oak trees, and I've never had an issue with clogging since I installed them. And I didn't have to buy expensive replacement gutters.
Re: Keeping downspouts clean [Re: Klutch9] #5162667 07/16/19 02:10 PM
W
Warstud Offline
W
Re: Keeping downspouts clean [Re: Klutch9] #5162688 07/16/19 02:41 PM
G
Gebo Offline
G
In my situation, I had to remove 2 trees and my gutters are clean and my life is now much better.
One other option is a more frequent gutter cleaning and that gets old.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Keeping downspouts clean [Re: Klutch9] #5162710 07/16/19 03:04 PM
J
JLawrence08648 Offline
J
I have had the foam inserts for 5 years, no problems with 2 London Planetrees, a Red Oak, and a neighbor's Maple. I use to go up yearly to clean the gutters.
Re: Keeping downspouts clean [Re: Klutch9] #5162738 07/16/19 03:41 PM
A
A_Spruce Offline
A
So is it a gutter clogging problem or a downspout clogging problem? Gutter diverters can get expensive quickly, but they're supposed to work wonders at keeping leaves and debris out of the gutters. Adding an additional downspout to each side will help, the water won't have to travel as far through all the debris to an exit point.
One of the huge problems I've encountered over my 30 years in the trades is that one piece downspouts, those that have notched bends, rather than formed bends, installers tend to get lazy in the notching and end up blocking half the diameter of the downspout. My fix for this problem is to simply install preformed elbows so that it is a full diameter conduit that won't catch leaves and debris.
I've got an oak tree that drops leaves year round, so I feel your pain with gutters clogging with debris. During the fall when leaves are at their worst, we blow the gutters out with a leaf blower as needed to keep them clear.
'03 Suburban
Re: Keeping downspouts clean [Re: JLawrence08648] #5162836 07/16/19 06:07 PM
doitmyself Offline
The OP stated that the screen types get covered over,clogged, and made things worse. Don't the foam inserts get clogged up from debris sitting on top of them also?
[Linked Image]
Here's a page that shows many different types: https://www.gutterguys.com/Gutter-Protection-18%7CGet-The-Facts---Free-Report-70.htm
Re: Keeping downspouts clean [Re: PimTac] #5163033 07/16/19 10:59 PM
G
Garak Offline
G
I do like that!
Plain, simple Garak.
Re: Keeping downspouts clean [Re: PimTac] #5163077 07/17/19 03:07 AM
V
va2001ss Offline
V
I had fought clogged gutters for 15 years on my house. I finally took a neighbor's advise and put these leaf guard gutters on 4 years ago and haven't had a clogged gutter since. My house is surrounded by hard woods as well. The design just works. I believe the 3x4 downspouts that are installed with this system really contribute to their efficiency. The house originally came with 2x3 downspouts.
2018 Chevrolet Malibu 2.0T LTG
2013 Chevrolet Tahoe 5.3 LMG
Re: Keeping downspouts clean [Re: Klutch9] #5163119 07/17/19 05:19 AM
Z
zzyzzx Offline
Z
Either better gutter guards or remove the trees.
Re: Keeping downspouts clean [Re: zzyzzx] #5163172 07/17/19 06:23 AM
doitmyself Offline
Then you have to live with affecting climate change and that whole carbon sequestration thing. LOL Do the helmet type leaf guards like leafguardgutter handle ice dams o.k.? They seem the best otherwise.
