OAI/Polaris analyst has on average 60 seconds per sample to evaluate and complete. Not surprised their interpretation is way off.
If you use the same Component ID and Secondary ID they should have shown both. You can email them and tell them to combine them.
From a VOA in 2018, Schaeffer had over 400 ppm sodium. They have Non-Disclosure Agreements with manufacturers for oil profiles, and should have not flagged sodium. Apparently they did not look at the profile. Again they have only 60 seconds to complete.
The copper content is extremely high. OAI/Polaris have arbitrary wear limits, often much higher than real world averages and limits. They do not track lube time, and claim it is irrelevant which tells you much about their reports.
The margin for error for Nickel is +/- 1.3 ppm at this low value, and the range for even considering it is 5-40 per ASTM. Again another bogus flagging.
The TBN method they use does not show the full reserve capacity of anti-oxidant additives, add 2-3 points for the real value.
What was your copper content from the last report?
