Originally Posted by WillB
Performance improvements stocks it, some cdn tire parts spurce stores do too.
This?
https://performanceimprovements.com/products/RL30604
Thank you. I recently found a place thst strocks Ref line - I will pick so e up.
Originally Posted by slacktide_bitog
It's group III synthetic. In fact, all licensed ATF+4 on Chrysler's approved list is the same since they are so strict. Not only is it group III, it's the same group III from one of three suppliers, plus a specific Lubrizol add pack.
If you can afford it, Redline C+ uses the same add pack as licensed ATF+4 but with a better base stock.
Where is the place that stocks Redline? It is not easy to find around here!
Oh, good to know, I will look into that, thanks!
