ATF-4?
It's group III synthetic. In fact, all licensed ATF+4 on Chrysler's approved list is the same since they are so strict. Not only is it group III, it's the same group III from one of three suppliers, plus a specific Lubrizol add pack.
If you can afford it, Redline C+ uses the same add pack as licensed ATF+4 but with a better base stock.
If you mean atf+4 then definitely yes. It's a group 3 base oil with a specific add pack. All atf+4 is the same, and only c+ is better being group 4 base oil. Would only put c+ in if you live in the barren Arctic tundra though...
This?
https://performanceimprovements.com/products/RL30604
Thank you. I recently found a place thst strocks Ref line - I will pick so e up.
Originally Posted by WillB
This?
Where is the place that stocks Redline? It is not easy to find around here!
Performance improvements stocks it, some cdn tire parts spurce stores do too.
This?
This?
Oh, good to know, I will look into that, thanks!
Petro Canada ATF+4 stacks up pretty well against Redline, and is readily available.
https://lubricants.petro-canada.com/en-ca/brand/atf-4
I cannot think of any ATF+4 which does not stack up well against C+. Redline should name it's product C-.
I agree,
Best ATF+4 fluid I've ever used is Redline C+.
