Owners Manual Recommendations 2019 Ram
by Snagglefoot - 12/09/19 12:22 PM
What engine RPM = maximum alternator output?
by Ed_Flecko - 12/09/19 11:41 AM
Supertech 3260
by Bettez88 - 12/09/19 10:06 AM
When the repair bill is 3.5 times what was estimated.
by motor_oil_madman - 12/09/19 09:59 AM
I See Better @ Night w/ Halogen Beams than HID/LED
by LoneRanger - 12/09/19 09:15 AM
Castrol GTX MAGNATEC Walmart
by MarkM66 - 12/09/19 08:03 AM
BITOG Standard of Conduct
by dnewton3 - 12/09/19 07:23 AM
Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
EddieO, streky, LpggasBottles, redradar, Jonas_K
70073 Registered Users
95 registered members (2011335d, alarmguy, Anduril, AlaskaMike, 1978elcamino, AndyB, 5 invisible), 2,119 guests, and 74 spiders.
Topics298,482
Posts5,136,404
Members70,073
Most Online3,589
Nov 2nd, 2019
Page 2 of 4 1 2 3 4
Re: fully synthetic 10w30 recomendation plz [Re: user52165] #5161537 07/15/19 12:31 PM
CR94 Offline
Originally Posted by user52165
Originally Posted by ARCOgraphite
... After a couple weeks of slow as mud light throttle acceleration, you will want to go back to a 5W20
... Do you have some thing to support this astounding statement?
Do we have to split into extremist camps, one claiming there's no difference in drag with higher-than-specified viscosity, and the other camp exaggerating the difference? Just recognize reality, folks! That's that the difference will be real, but not huge.
2011 Toyota Prius now at 107K
Re: fully synthetic 10w30 recomendation plz [Re: CR94] #5161565 07/15/19 01:03 PM
1
1978elcamino Online Content OP
OP Online Content
1
I know right, its not like Im going to 20w50 or anything. I just want to experiment with a handful of oil choices here. This will be the first 10w, but want to make sure its a a solid 10w, not something advertised as a 10w but closer to a 5w.
Maybe I will dump some lucas in for good measure.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161578 07/15/19 01:23 PM
K
kschachn Online Content
Online Content
K
Again as I mentioned before, the winter rating is irrelevant. You need to learn the difference between a winter rating and the operating grade. Both the 5W-30 and the 10W-30 are 30 grade oils. Your constant focus on the winter grade is misplaced, a 5W oil is not thinner than a 10W except at low temperatures (below 0F or so).
Lucas will increase the operating viscosity but will also dilute the additives. The best way to get an oil that's thicker than a 30 grade is to use a fully formulated 40 grade, not an additive.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: fully synthetic 10w30 recomendation plz [Re: user52165] #5161606 07/15/19 01:56 PM
K
ka9mnx Offline
K
You want a "thick" 10W30? That means high HTHS not high KV100.
After a couple weeks of slow as mud light throttle acceleration, you will want to go back to a 5W20 smile
HTHS = 3.5
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161624 07/15/19 02:07 PM
ChemLabNL Offline
HTHS 3.5? I don't know on any in USA.
Use Mobil 1 High Mileage 10w30.
Re: fully synthetic 10w30 recomendation plz [Re: ka9mnx] #5161649 07/15/19 02:34 PM
H
hatt Offline
H
HTHS = 3.5
I'm running a 3.5 HTHS in a 5.0 right now. You're not telling the difference in a 360+ HP pickup truck by driving around.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161669 07/15/19 02:58 PM
R
Rand Online Content
Online Content
R
Lots of folks try t6 5w40, 5w30 and motorcraft 5w50. I personally have tried MC 5w30 and currently in there I have t6 5w40. I think next change I would like to try a 10w30. Is there a sn+ 10w30 out there?
Seems like you want a "thick 30" oil this isnt determined by the first number a 5w30, 10w30, or even 15w30. would all be relatively similar and the 10w30 could be the thinnest of the 3.
Arco posts without his meds frequently so if something looks wacked out I usually just ignore it, The other day he was quoting himself form another forum and calling it wisdom.
If you want a thick 30 you are better off mixing a couple quarts of 10w40 with the same additive package to your preferred 30wt oil..
an example would be using 2quarts 10w40 in place of 2 of your quarts (of 10w30 or whatever)
making sure its the same brand. ie not mixing shell and Mobil 1.
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161725 07/15/19 03:52 PM
T
tig1 Offline
T
I put 354K on my old 91 Ford Ranger 3.0. When I sold it the engine still ran great and never had the valve covers removed, and no more oil use when sold than when purchased. Oil used was M1 10-30 at 10K OCIs.
2007 Ford Fusion 250,000 miles
M1 5-20HM
2017 Ford Fusion 83K
M1 0-20EP
M1 ATF and M1 ATF LV
M1 10-30 in all OPE
MC filters
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161738 07/15/19 04:06 PM
SR5 Offline
M1 10W-30 High Mileage it has a HTHS of 3.5 cP when a regular GF-5 oil would be about 3.1 +/- 0.1 cP.
Also the M1 10W30 HM is one of the few oils that is rated both API SN-Plus and Euro ACEA A3/B3.
It’s a great looking oil.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161743 07/15/19 04:11 PM
SilverFusion2010 Offline
M1 HM 10w-30 is my go to if I’m not running HDEO
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: fully synthetic 10w30 recomendation plz [Re: SR5] #5161777 07/15/19 04:49 PM
B
bbhero Offline
B
Great post here ^^^^
A real stout 10w30 made by M-1.
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: fully synthetic 10w30 recomendation plz [Re: bbhero] #5161785 07/15/19 04:57 PM
SR5 Offline
Hey BBhero,
Always good to see you around mate.
Re: fully synthetic 10w30 recomendation plz [Re: user52165] #5161786 07/15/19 04:57 PM
Silverado12 Offline
I was thinking the same thing. FWIW I use Motorcraft semi-syn 5W-30 in my 2018 Mustang 5.0 and my 4.6 Modulars in my older Mustangs. Get it at Wally's for a little under 20 bucks per gallon.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161790 07/15/19 05:02 PM
Silverado12 Offline
In the owners manual of my Briggs powered riding mower, it interestingly says that if You don't use a 30 straight grade to use 5W-30 full syn. Don't know why it doesn't mention 10W.
00 Mustang GT auto
Re: fully synthetic 10w30 recomendation plz [Re: 1978elcamino] #5161886 07/15/19 06:34 PM
G
Gokhan Offline
G
Looking for a fully synthetic 10w30. Was going to try QSUD but learned its on the thinner side similar to a 5w. Would like to stick with a solid 10w non high mileage available at walmart.
Where did you learn it that QSUD 10W-30 is on the thinner side? This is incorrect. QSUD 10W-30 is on the thicker side. It uses a high-VI base oil and KV100 ~ 11 cSt with minimal VII (VI = 150). Full-shear viscosity (without any VII effect) should be at or close to 2.9 cP; so, it's almost as thick as a monograde SAE 30. HTHS viscosity is probably 3.3 cP or at least 3.2 cP.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 1,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Page 2 of 4 1 2 3 4
