Originally Posted by Dave9
Originally Posted by Cujet
Originally Posted by atikovi
Only time will tell how these small displacement high output engines do in a heavy vehicle. Seems highly stressed but I'm no engineer so don't know how beefed up the internals are.
We already know. People pile on the miles on work trucks, and there are more than a few with very high miles. There are a few 2.7L F150's over 200K miles without trouble and a good number of 3.5L ecoboosts with near 400K miles. The common theme seems to be
good maintenance expensive repairs
Fixed that for you.
There are examples of many different vehicles including those known to average low miles before major problems, achieving high miles with good maintenance. Better designs don't need "good" maintenance beyond 8K oil changes to achieve high mileage. Okay maybe refill the wiper fluid when it is empty too.
Let's not pretend the 3.5L with its internal water pump is a long lasting design from the two facts that practically nobody checks their oil for coolant contamination before every drive, and nobody wants to shell out over $1K to do a mere water pump if they're
lucky enough to catch it when it fails rather than engine damage symptoms cropping up.
The trend continues, it has never been more expensive to maintain and repair vehicles. Granted it's not just the engine. It all adds up including dual injection which mitigates one problem only to create another in higher repair cost later.
I don't dismiss the fuel savings for those who drive high miles, that could make these designs a wise choice, but to pretend they're some how magically as reliable because a few have hit 100's thousands miles, is overlooking real world rising repair costs given the same criteria for yearly mileage averages or at least close enough.
I think what cujet was pointing to that apparently triggered you to author the above diatribe, was simply that owners should adhere to the published maintenance schedule on these trucks. Not particularly a difficult thing to do, and no more expensive to maintain in that manner than any truck of the same class from competing brands.
