A few years ago i had a rough idling issue with the E39 M54 (6 Cylinder N/A) and i remember that one of the methods used to diagnose if the PCV was broken (Apart from disassembling it) was to pull the oil fill cap with the engine idling and if there was an insane vacuum holding the oil fill cap then the PCV valve probably had a problem.
So my question is, is that the same with other engines? (Diesel Toyota and Gasoline 4 cyl N/A Kia)
