I like what I see except for the related super high viscosity index, low viscosity base oil mixture, and somewhat high volatility. Thank you for the VOA!
Did you ever get your VOA results back? If so I would love to see it.I just sent in a ENOES Racing Street 0W-20 virgin oil sample in for testing. I wanted to open up a thread so someone else didn't also pay for a test. Results should be back in two weeks. This is going into my 2018 Titan XD 5.6L and I will follow-up with a UOA sample in 5,000 miles. I found it interesting the bottle is a trademarked design from Yamaha.
It's the 18th post in this thread.Did you ever get your VOA results back? If so I would love to see it.
Wouldn’t using a quart of RL 0W-20 achieve most of that as well?If one does want a higher HTHSV rated 0W-20 one good and cost effective way to do it is to buy a quart of RL's new Powersports 0W-40 (VI 221.5) and add 5-10% to your 0W-20. It would only marginally lower the VI and significantly raise the ZDDP level around 100 ppm plus add a bit of highly polar polyol ester.
