Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
68 registered members (AndyB, 94astro, 4WD, Boomer, AurionX2, 6 invisible), 1,462 guests, and 17 spiders.
Topics303,499
Posts5,235,235
Members71,061
Page 2 of 2 1 2
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: OVERKILL] #4720779 04/08/18 05:36 PM
SOHCman Offline
OVERKILL, is that a stock roller lifter from a 302? What milage did that happen at, or was this a performance engine?
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #4721202 04/09/18 06:29 AM
SubieRubyRoo Offline
392 Cam
Gotta be SADI at $80. Looking at some of the cam pics it is weird though.. the way it's really only eating the ramps makes me wonder if part of the issue is insufficient valvespring pressure, and the lifter is bouncing on the lobe. That would definitely lead to busting some needles and therefore locking up the roller, then digesting the cam lobe first?
De omnibus dubitandum.
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: SOHCman] #4721255 04/09/18 08:03 AM
O
OVERKILL Offline
O
That's an aftermarket stock-style roller lifter from a 302. This was a built engine, which came in a car my buddy purchased, had less than 1,000Km on it. We reused quite a few parts from it including the heads. We did, temporarily, reuse that camshaft too, since it survived surprisingly well. It was eventually replaced by a re-grind of the same profile, however it never sounded the same so the re-grind was not an exact copy.
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: SubieRubyRoo] #4721256 04/09/18 08:03 AM
O
OVERKILL Offline
O
Originally Posted By: SubieRubyRoo
392 Cam
That's a strong case for them both being SADI (that price) and subsequently the only difference being the oil spec.
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #4861555 09/06/18 03:32 PM
B
blakegeo Offline
B
I read an article on this in Machinery Lubrication and they stated the cause was because they were cast in the 5.7l engine and were forged steel in the 6.4l engines
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: blakegeo] #5160402 07/14/19 11:50 AM
P
ProStreetCamaro Offline
P
I know this was from last year. Don't think for a second the 6.4 doesn't have lifter failures. I see it weekly on the Jeep and Durango SRT groups. No difference between the 5.7 and 6.4. I've had a 14 Jeep SRT and now an 18 Durango SRT myself. That dealer is full of it.
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #5174007 07/29/19 03:40 PM
E
earthbound Offline
E
so knowing this issue is out there...do you guys recommend sticking with the 5w20 mfg spec or will a thicker oil ie: 5w30 redline that supposedly works wonders in quieting down the tick work better. I would love to know if using a certain oil spec would prevent me down the line from having lifter failure issues.
19' Honda Crv 1.5T
19' Ram 1500 5.7 Hemi
06' Pontiac/yoda Vibe
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #5267465 11/14/19 07:56 PM
spiderbypass Offline
One thing have learned from following posts on bitog over the years is that exemplary engineering can overcome poor quality oil, but the “best” synthetic oils can never fully overcome engineering deficits.
Insecurity with overcompensation are the root of evil deeds.
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #5267633 11/14/19 10:50 PM
M
mattd Online Content
Online Content
M
This happened to a maxxforce DT with about 4000 hours on a “repaired” camshaft that they chose to cut costs on and paid for the repair twice. This shows the importance of camshaft hardness.
15169E5E-E807-44D4-B503-A561DC42DFD6.jpeg13B9F36E-66BA-40CA-A9A4-9EF48B9B1751.jpeg22032D9C-4BB4-48B9-8F6C-973612E789F6.jpeg09352903-0518-4590-98BE-84F82BBEAEA4.jpeg5FC5FD63-6AAA-4187-A6C9-9AB31F7DD2D5.jpeg5A1CF2E5-AFED-4BD7-93AE-1B06AE4609D6.jpeg
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: spiderbypass] #5267702 11/15/19 12:36 AM
MolaKule Offline
Global Moderator
Global Moderator
I think the problems were those of metallurgy and lack of proper heat treatment (hardening).
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: mattd] #5267813 11/15/19 07:47 AM
Skippy722 Offline
That rough turn between the lobes, looks like 250 finish! crzy I assume they’re induction hardened as well? How do you “fix” that??
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: Skippy722] #5268071 11/15/19 12:29 PM
M
Online Content
M
They had the original one fixed (the one pictured). The lifter retainer spun on the cam and destroyed it. I overhauled the engine out of chassis and put the original cam that was repaired back in. 10 months later are the photos in my previous post. Bought a new cam from the dealer and it has been fine since.
This is the picture of the lifter after the dog bone broke
ASE Master, L1, L2
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: das_peikko] #5272067 11/19/19 07:41 PM
1
1978elcamino Offline
1
You would think by now FCA would have a more robust cam. How long has it has it been, ten years?
Re: Camshaft and Lifter Wear on Chrysler Hemi Engines [Re: earthbound] #5272337 11/20/19 08:12 AM
Cujet Offline
https://www.schaeffler.com/remoteme...fler_2/tpi/downloads_8/tpi_176_de_en.pdf
As always, the property of oil that lubricates is viscosity. Lack of sufficient viscosity is a HUGE factor in roller bearing life. It's not unusual for insufficient viscosity to reduce roller bearing life by an order of magnitude.
Whether viscosity solves this problem or not is another matter entirely. As poor component quality or an insufficiently robust design probably won't be "fixed" by oil viscosity.
https://www.chargerforums.com/threads/answers-5-7l-hemi-camshaft-professional-failure-assay.382357/
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4499405/all/Molybdenum,_Cam_wear_and_Hemi_
Page 2 of 2 1 2
