Harbor Freight ball joint press.
Apple Valley, California
My jeep needed new ball joints. The shops in town that do that kind of work wanted $800+ to replace them. No way was I going to pay that. I picked up the HF ball joint press for about $70.
Thing worked great! My minor complaints are that the "C" could be a little bigger. 1/2 inch would be fine. Fumbling with the adapters can be a little aggravating,a 2nd set of hands would help a lot. A finer thread on the screw would make it easier to screw and push the joints in and out.
But for $70 its a great tool regardless. Took me 1 hr40 minutes start to finish to do all 4 ball joints.
Ya thats my caliper hanging from the hose. It fell from its resting spot 2 seconds before I took the pic.
  • Like
Reactions: JC1
Harbor freight can be a mechanic's delight. I just warrantied a 1/2 inch breaker bar that I've had since college, they gave me a new one no questions asked, The salesman actually commented on my bar: "The one with 3 lines on the handle got recalled years ago... how long have you had this?". I walked out 5 minutes later with a brand new one. I love avoiding making the Snap-On rep's next truck payment.
I have that ball joint press.. Maddox is the brand. I've used it to do ball joints on a 99 Ford Crown Vic, my 2008 Dodge Ram 1500, and my brother's 2009 Dodge Charger. The last one was a major pain to do but it worked putting them in.. I had to use my Snap-On 20 ton press to get the old ones out though... that 20 ton press was the best $80 I spent at a yard sale.
I've got the 'Merican-made version of this. But I still had to take some black pipe and make some of the adapters.
They need the thicker coarser thread to not strip out. Some anti-sieze or moly grease on the threads helps too. I torque the tool down nice and tight then whale on the knuckle with my hammer so the vibrations can loosen things. Can then get a little more torque on the tool-- repeat until loose.
New parts go in the freezer to help them slide in.
I thought about using this to change u joints. Then I considered borrowing one from AZ. I finally went with the 2.5 lb hammer instead. This would be handy to have around.
It has instructions on how to use it to do ujoints. I just use a socket and hammer myself.
We have a small c clamp press at the shop that works really well for u joints. It may actually be a u joint press. All I know is it works for that job. My dad does them with the hammer and socket method. I personally prefer the press.
I use a horizontal press aka a bench vise mostly for doing U joints, some elcheapo sockets makes it a quick and easy job.
+1 on using high moly grease on the threads of threaded compression tools, Klann specifies its use before every use.
