98 registered members (Anduril, 77GrandPrix, 2015_PSD, 53' Stude, ARCOgraphite, A310, 7 invisible),
2,051
guests, and 23
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,761
Posts5,140,716
Members70,117
Most Online3,589 Nov 2nd, 2019
Q50 VQ37 Ester oils
#5159695
07/13/19 03:41 PM
Thugzy
OP
OP
Posts: 223 |
i just aquired a mint condition 2015 Q50 AWD VQ37 with 50k miles. Original owner all service records done at Nissan. i noticed service records state use of Nissan Ester oil 5w30 all its life.
This car i plan to keep for longevity for another 5-7 years.
60% hwy / 30% city... Toronto Climate (-10C winters/+30C humid summers) 40km each way to and from daily...
it seems these engines are quite complex yet built proof.
As i read everywhere, Ester is needed fto compliment the valvetran components.
I read Nissan Ester is good, bad.. use Redline, use Mobil 1.... im confused...
so based on my situation, and past UOAs on VQ37s, what do you fellows recommend? stick with Nissan Ester or or is there somthing better??
TIA
'18 F150 Lariat 3.5EB - QSUD 5W30/PG2500EX '15 F150 Lariat 5.0 - PUP 5W30/Motorcraft '01 S2000 - M1 0W40/Toyo Roki '15 Q50 AWD VQ37 - M1 FS 0W40/M1 Filter '13 Crosstrek - QSAD 5W30/Champ Filter
Re: Q50 VQ37 Ester oils
[Re: Thugzy]
#5159709
07/13/19 03:59 PM
hemitruck
Posts: 483 |
Redline. Better add pack.
[Re: Thugzy]
#5159727
07/13/19 04:52 PM
Garak
Posts: 28,128 |
Nissan ester is extremely overpriced and it is not needed. I never touched it. Look at my signature for what's in my sump. I've run HDEOs for the past several years. I have no consumption and things are quiet, which is about as good as I can ask for. Blue Wave Energy can get you what I'm running at a very attractive price, and up here it comes in 5 litre jugs and fulfills API and viscosity requirements by Infiniti's manual wording. I had no problems with winter starts, unaided even, this year with us having the worst February on record.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, Wix 57356 1984 F-150 4.9L - Quaker State GB 10w-30, Wix 51515
[Re: Thugzy]
#5159815
07/13/19 06:41 PM
Mad_Hatter
Posts: 2,957 |
Would adding Lubegard Biotech work?? ? My understanding is it's all ester with gobs of moly (not the MoS2 type).
[Re: Mad_Hatter]
#5159839
07/13/19 07:07 PM
Garak
Posts: 28,128 |
The Nissan Genuine Ester Oil's use of the term "ester" was as much a marketing term as anything else. It wasn't an ester based oil in the least. I ran PYB in mine for a long time at the outset and was quite happy with it, too. They're not that fussy. Synthetic isn't even mandatory.
[Re: Thugzy]
#5159886
07/13/19 07:56 PM
JAG
Posts: 5,320 |
[Re: Garak]
#5159889
07/13/19 07:58 PM
bbhero
Posts: 7,219 |
What Garak stated is absolutely correct ^^^^^^^^
Nissan Altima 3.5 Coupe Napa full synthetic 5w30 Wix 57356 Oil filter "Treat your family like your friends and treat your friends like your family."
[Re: Garak]
#5159890
07/13/19 08:00 PM
Thugzy
OP
OP
Posts: 223 |
what's the thoughts of using M1 FS 0W40 in the VQ37? its my go to oil in my S2k and EcoBoost.
i read 370z owners using it
[Re: Thugzy]
#5159913
07/13/19 08:32 PM
burla
Posts: 1,144 |
redline 5w30 or Motul 300v.
[Re: Thugzy]
#5159964
07/13/19 09:41 PM
burla
Posts: 1,144 |
Unless that is a di turbo, then that should be the first thing out of your mouth. In that case, find a low CA oil.
[Re: Thugzy]
#5159974
07/13/19 10:11 PM
Garak
Posts: 28,128 |
what's the thoughts of using M1 FS 0W40 in the VQ37? That's perfectly suitable as well. Any A3/B4 lubricant will work similarly. Any C3 lubricant will also work. Don't sell an E6 like I'm using short, either. It has similar HTHS to that found in M1 0w-40 and other A3/B4 lubricants. Burla's suggestions of Red Line or Motul are certainly suitable for use, but not for price. If I'm recommending you not use $20+ a litre oil from the dealer, I'm similarly going to tell you not to buy $20+ a litre boutique or Euro oil. If you want to spend money on Red Line, spend it on SI-1 and use it a couple or more times a year in the gas. $15 worth of PYB will serve you just as well as $100 worth of Red Line for ordinary usage.
[Re: Thugzy]
#5160008
07/13/19 11:25 PM
burla
Posts: 1,144 |
i read 370z owners using it No doubt that is one great oil, but you realize it isn't sn+ yes? So when it comes to lspi have you researched it and don't believe the risk or haven't researched it? sn+ is specefically for di turbo's like the eco boost.
[Re: Thugzy]
#5160010
07/13/19 11:28 PM
burla
Posts: 1,144 |
what engine is in your car?
[Re: burla]
#5160011
07/13/19 11:29 PM
bbhero
Posts: 7,219 |
VQ 3.7 L.... 2015 version... NA EFI motor.
[Re: Thugzy]
#5160205
07/14/19 08:11 AM
Eddddd
Posts: 33 |
I have a 370z with the VQ37. These engines are very hard on oil and Nissan recommend Ester oil. Though the engine can get by with a very good synthetic that is not Group V, I highly recommend an Ester base oil. I use Redline 5W30 and change my oil every 5k. I have done several UAOs. There wear some high metal count but it went down over time. It’s said you will get unusual UAOs with Redline due to the “cleaning” of Redline. Nissan Ester is too expensive for what you get. I have seen many use Motul and it is a good Ester oil as well. It’s just hard to find for me.
