On the back of the Valvoline Maxlife ATF bottle it says that the product can be used in transmissions specifying Honda Z1 and Mercon V. I’ve drained my wife’s 99 Accord 4 times since new (83K now) and used Maxlife ATF the last two times. It seems to work as well as the Honda ATF so I’m going to try if in my Ford 4R70W soon. I’m assuming even if it’s not the best ATF available that it will work fine if changed regularly. I like the idea of keeping one ATF on the shelf for both cars. Has anyone else used Maxlife in his/her Ford 4R70W? It’s newer than the Honda so I’m somewhat reluctant to try it but I probably will soon.
