Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
Tar, cast71, bamadog1, jrogahn, DeathByNissan55
69571 Registered Users
25 registered members (billt460, Ag76, carlprop, Bailes1992, amng04, 5 invisible), 701 guests, and 25 spiders.
Topics296,028
Posts5,089,556
Members69,571
Most Online3,532
Jul 30th, 2019
2000 Jeep Cherokee turn signals out #5158749 07/12/19 02:47 PM
J
Jetsfan421 Offline OP
J
My dad has a Jeep Cherokee that has intermittent blinker outage. I've checked the blinker fluid and it's all topped off. What else can be causing this problem? Relays? His doors randomly lock on their own like Gremlins are controlling them. Any help is appreciated.
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158752 07/12/19 02:53 PM
B
bullwinkle Offline
B
I know the door wiring harnesses can go bad (I need one on my ‘98 for the locks & windows), not sure about turn signals, haven’t lost those yet.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158755 07/12/19 02:56 PM
J
J
Thanks for the quick reply Bullwinkle. Will look into the wiring harness.
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158758 07/12/19 02:58 PM
J
Jmlo96 Offline
J
I used to have a 97 Cherokee. At one time, it had issues with the 4 way flashers turning on with the turn signals. This was a long time ago, so bear with me. But as I recall, the issue had to do with the multifunction switch having an issue. I'm about 80 percent sure we solved the problem by changing the multifunction switch.
As for the door looks, check the wires in the doors. Jeep used cheap wiring that has a tendency to wear the insulation out from opening and closing the doors. Eventually the wires could also break. This caused issues with the speakers, power windows, and power locks. If one of those wires is grounding out, that could be your door lock issue. To troubleshoot this, I'd try unplugging each front power door lock switch until the lock problem stops.
Also, if it has remote keyless entry, it's possible that could be having an issue.
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158763 07/12/19 03:04 PM
J
J
Welcome to the forum Jmlo96. I will check out the wireless entry system.
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158810 07/12/19 03:53 PM
W
Wheel Offline
W
It might be worth verifying that you have a good ground as well.
2009 Subaru Legacy (N/A)
Pennzoil Platinum Plus and NAPA filter
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5158961 07/12/19 06:59 PM
X
XCIDMigs Offline
X
https://www.youtube.com/watch?v=HEZDdqyONdQ
That's the answer to the intermitten flasher failure, the other responses about the wiring harness that is for the driver door explains why you get the weird activations of the locks etc. Open up or remove the giant black rubber cover inside the door jam and you will likely find one of the larger gauge wires is either actually broken or just has a weird broken part which you can replace or repair.
This is one of the worst vehicles I have ever had for this type of stupid electrical gremlins, the HVAC controls is another big mess....
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5159091 07/12/19 09:35 PM
E
earlyre Offline
E
I know some other 2000 Chry-co vehicles with random activation of things like power windows, wipers,etc. caravans come to mind especially. on those,at least some of the blame falls to bad solder on the power distribution unit...early days of lead free solder... also defective clocksprings...all kinds of fun stuff.
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5161375 07/15/19 10:40 AM
G
GMBoy Offline
G
Turn signal switch. Easy to replace and not expensive.
Re: 2000 Jeep Cherokee turn signals out [Re: Jetsfan421] #5161526 07/15/19 01:22 PM
W
wings&wheels Offline
W
I had an intermittent light and signal problem with my GC. Drove me nuts, was almost going to take to the dealer but I followed the circuits and it turned out to be a loose connection at the bulb out monitor box inline with the rear light harness. Was in the base of the left rear pillar IIRC.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
