Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
101 registered members (1WildPig, AdditiveOCD, alchargo, ad244, 53' Stude, 4WD, 10 invisible), 2,289 guests, and 30 spiders.
Topics291,935
Posts5,013,732
Members68,670
Most Online2,967
Mar 10th, 2019
Pork tenderloin on gas grill with smoker box? #5158473
07/12/19 09:06 AM
07/12/19 09:06 AM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
I have a Weber spirit and just purchased a smoker box. I am going to do a couple of one and a half pound whole tenderloins. I’ve done some reading which suggests doing them indirectly, which I think I am good with.
My plan is to soak my chips, get them in the box on the preheated grill, get them smoking, turn off the middle burner, turn down the other burners to medium/medium low, and then I’m guessing I’ll be looking at about and hour or so cooking time.
Am I in the ballpark? First time I am using a smoker box and cooking indirectly, so any tips are appreciated.
Thanks.
2018 Honda Accord Sport 2.0T/10 Speed
Modern Steel Metallic/Black
Factory Fill/Filter
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5158488
07/12/19 09:20 AM
07/12/19 09:20 AM
Long Valley, NJ
Sluggo0018 Online content
Sluggo0018  Online Content
Long Valley, NJ
I'd say you are in the right ballpark. Soak more chips than you think you will need. You can always dry the leftovers out and reuse another day.
Also, be really careful not to overcook the tenderloins. There is almost no fat on that meat and overcooking them even just a little bit will lead to disappointing results. I can't convince my mother-in-law of this, but you no longer have to cook pork to well done to kill trichinosis, etc. It is ok to cook to medium (140-145 internal temp) then remove from heat, cover with foil and let rest for 10-15 minutes before slicing. They will be much juicier at lower temps. My MIL insists on cooking her pork loin to 175-185 and it tastes like compressed saw dust. It is almost inedible without a sauce or gravy. She is still living back in the day when raw pork had some nasty stuff that had to be killed with high heat.
What type of wood are you using? I would stay away from stronger woods like mesquite and go with a milder hickory or pecan.
Keep it low and slow for best results.
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5158530
07/12/19 10:06 AM
07/12/19 10:06 AM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Super helpful. Thank you so much. Really appreciated.
Factory Fill/Filter
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5158535
07/12/19 10:11 AM
07/12/19 10:11 AM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
It sounds like you've got a solid plan. Indirect cooking on Weber gas grills is actually straightforward, as they seal up pretty well. Still, any breezes may cause temps to fluctuate, so try to place the grill away from the prevailing winds. You may only need a single burner lit; two lit burners, even on low, may lead to too high a temp. I have a Genesis with the Weber smoking box that sits along the side of the burner. Sometimes the chips would go beyond smoldering and just catch fire, causing a temp spike. I think that was more the design of the Weber smoking box, so you likely won't have a similar problem. I kept a squirt bottle with some water to tamp down any flames from the chips. A digital remote thermometer with a high and low temp alarm is nice to have so you don't have to hover over the grill. Give yourself a nice cooking temp window and if you hear the alarm, check it out. Otherwise, let it be.
As noted above, USDA guidelines for safe temping of pork is now 145 degrees with a short rest. No need to kill it twice by cooking to 160+.
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5158635
07/12/19 12:26 PM
07/12/19 12:26 PM
Florida
hatt Offline
hatt  Offline
Florida
I have a Spirit 2 and cook tenderloins. Turn on all the burners and let the grill heat up. Leave on burner on. On high. Sear the tenderloins 4-5 minutes on each side. Take them off the direct heat and cook another 10-15 minutes. You could do something similar with the smoke box. I wouldn't soak the chips however since you want max smoke with the short cooking times. I've never had results I like cooking low fat meat for long periods.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5158727
07/12/19 02:21 PM
07/12/19 02:21 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
Very little room for error on these per the previous comments.
Definitely use a meat thermometer with a lead so you can monitor internal meat temps with the grill lid closed.
Watch the thermometer and remove at 145° with a 5 minute rest after. Your shooting for a final internal temp of about 155°.
If you overshoot it will be as dry as a desert.
Good luck! cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Pork tenderloin on gas grill with smoker box? [Re: BTLew81] #5159949
07/13/19 10:12 PM
07/13/19 10:12 PM
Germantown, MD
greenjp Offline
greenjp  Offline
Germantown, MD
You guys are crazy. I pull my pork tenderloins at 137, awesome and haven't gotten sick once smile This is actually the temp recommended in a great marinade recipe we use frequently from a Barefoot Contessa cookbook.
jeff
