Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
83 registered members (4WD, 69GTX, 2strokeNorthstar, 2010Civic, 53' Stude, 12 invisible), 1,523 guests, and 24 spiders.
Topics296,195
Posts5,093,298
Members69,612
Most Online3,532
Jul 30th, 2019
FL500S and TG 10575 different.spec #5158412 07/12/19 08:01 AM
B
Baveux Offline OP
B
I'm about to install a TG10575 that I got for free from a friend but... I always used a FL500S on my truck since I bought it new.
Yesterday I wrote a letter to Fram and they say that it meets the OEM requirement, however the bypass valve is set at 22psi on the Fram and apparently a 8 on the motorcraft, how important is this ?
Fram Flow rate tested a 3GPM using std method, but flow more than according to fram, but how much more since ? enough to meet the motorcraft flowing at 10/12 gpm .
I dont care to ditch the 2 fram i got for free if according to you that it should be more in line with ford spec
Re: FL500S and TG 10575 different.spec [Re: Baveux] #5158446 07/12/19 08:32 AM
Snagglefoot Offline
Shine a flashlight down the threaded hole. At the end will be the bypass valve. It will be either black or white. If it’s black you have the old one. If it’s white you have the 22 psi version. This has been posted somewhere. Search it and you might find it. smile
If you want the job done right......do it yourself.
Re: FL500S and TG 10575 different.spec [Re: Snagglefoot] #5158478 07/12/19 09:11 AM
B
Baveux Offline OP
B
Thanks snagglefoot, its the white BPV. I have sent another message to Fram and contrarily to what I read on some post the FL500S BP valve is set between 17/23 PSI ( 2009 spec ) and not 8 psi
So Fram will be ok at 22 ... so my paranoia is all gone , the TG will be put to good use, hopefully that they will performed as good as the fl500 s in real life :-)
Re: FL500S and TG 10575 different.spec [Re: Baveux] #5158497 07/12/19 09:26 AM
H
HemiHawk Offline
H
Two thoughts from reading about the filters on the 5.0 (assuming your F150 is the 5.0?). The FL500s has the threadend bypass which seems to have some benefits of its own. Then for the bypass pressure, it seems Ford thought to have that in place to get the oil where it needs to be either during cold starts or high RPM/Load times. I know some 5.0 owners have used the FL820s and the racing versions but those also have the higher PSI raiting. I've seen some mention of Ford engineers saying that the FL820s racing filter will work fine even with the higher PSI rating, since the flow should should be higher than the FL500s.
2015 Mustang GT
2017 VW GTI sport
1995 Mustang GTS
Re: FL500S and TG 10575 different.spec [Re: Baveux] #5158695 07/12/19 01:44 PM
L
Linctex Offline
L
It will be BETTER than the FL500S - the flow will be better, and the filtration efficiency is better.
Re: FL500S and TG 10575 different.spec [Re: Linctex] #5158802 07/12/19 03:40 PM
B
Baveux Offline OP
B
Linctex thats a real Good thing to read :-)
HemiHawk ....my engine is the 3.5 eco in a f150 2014
thanks to you guys
Re: FL500S and TG 10575 different.spec [Re: Baveux] #5159934 07/13/19 09:55 PM
dnewton3 Offline
Global Moderator
Global Moderator
The Wix eqiv is # 57502; BP at 22psi.
Donaldson P577066; 22psi.
Baldwin 7449; 20 psi.
Purolator products PL22500; 22psi.
I don't think you need to worry; the market generally shows 22"ish" is what's expected.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
