Originally Posted by kschachn
Originally Posted by RDY4WAR
I have a good friend up in Canada who drives a truck delivering liquid nitrogen all over North America. He said they never want to see the rear tires go below 80 psi as that is a danger zone for a blowout. The sidewall flexes too much which generates internal friction and warping which can cause the tire to blowout. He said he aims for 95 psi in rear tires and 110 psi in front tires with a range of 85-100 psi for rear and 100-115 psi for front. However, he said you will never get an accurate reading on a gauge with hot tires. He carries a sledgehammer in the cab and when he stops, he bangs the tires with the hammer. If the tire is low on pressure, it'll make a dull sound. If it's overinflated, it'll make a ping-like sound. He will then verify it with a gauge and/or let a little out and bang again.
He said the most calls his company gets from drivers with blown tires is people going from sea level to high elevation. As the ambient pressure decreases, tire pressure increases (relatively), and increases the chance of over-inflation and a blowout if the pressure isn't dropped accordingly.
If the 3 or so PSI difference between a high and a lower altitude is causing tire failure then there's something else going on.
Maybe his sledge hammer method of determining tire pressure reflects his skill in other areas.
He may be doing it that way, but its not the way it is trained by tire manufacturers. Been to truck trade shows where we were given the hammer and no way to tell if the tire had 80 psi or 100 psi, and the 80 psi is basically a flat tire for trucking purposes.
