Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
86 registered members (10WSmuckers, 53' Stude, ABN_CBT_ENGR, 2015_PSD, 4WD, 330indy, 11 invisible), 2,519 guests, and 25 spiders.
Topics305,939
Posts5,283,310
Members71,540
How to use dielectric grease ? #5157207 07/10/19 10:11 PM
ST2008 Offline OP
Hi
Can someone give me an official or a credible link regarding how to use the dielectric grease? I watched some video in Youtube and there are conflict messages. Some state that we should never apply the dielectric grease on the electrical connection. But other state the opposite.
thx
Re: How to use dielectric grease ? [Re: ST2008] #5157217 07/10/19 10:28 PM
Billbert Offline
Dielectric grease locks out air and corrosion on electric contacts and connections. It should be used on any electric connection.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: How to use dielectric grease ? [Re: ST2008] #5157218 07/10/19 10:29 PM
W
Warstud Offline
W
From the back of my CRC dielectric can >>>>>> Seals , lubricates, protects and insulates eletrical contacts ,spark plugs, battery terminals and fasteners from moisture. Lubricates and seals rubber and plastic parts-including O-rings. Waterproofs electrical contacts and components to protect against arcing due to moisture.
Re: How to use dielectric grease ? [Re: ST2008] #5157244 07/10/19 11:01 PM
V
vavavroom Offline
V
Where the electric connection is made, the grease gets squeezed out and you get metal-on-metal contact for good conductivity. Use dielectric grease for corrosion protection on battery terminals, screw-post connections etc. Also, use on the o-rings of sealed electric connectors and on spark plug boots. Since dielectric grease does not conduct electricity it helps prevent arcing and the leaking of current in the presence of moisture.
Re: How to use dielectric grease ? [Re: vavavroom] #5157250 07/10/19 11:17 PM
B
bsmithwins Offline
B
What he said.
BSW
Re: How to use dielectric grease ? [Re: ST2008] #5157360 07/11/19 05:07 AM
Snagglefoot Offline
“Over top” not “in between”. Dielectric grease is an insulator. For use with batteries, make up the cable to the terminal and then put the grease over top. If you put the grease on the terminal and then put on the cable you run the risk of totally actually insulating one from the other. However, folks get away with it because like a previous poster said the grease might be “squeezed “out enough to still have a metal to metal connection.
If you want the job done right......do it yourself.
Re: How to use dielectric grease ? [Re: ST2008] #5157399 07/11/19 06:23 AM
SHOZ Offline
I used some self leveling Dow silicone grease once on my battery terminals. It creeps and gravity will pull it down. Put it on top of my cables and after a month I stated having starting issues due to the insulating by the grease between post and cable.
But the last three cars I have not used any grease on the terminals.
If you have corrosion you have a leaking battery.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: How to use dielectric grease ? [Re: Snagglefoot] #5157462 07/11/19 07:58 AM
SVTCobra Offline
I found out the hard way not to use dielectric grease in between the battery post and the cable terminal. Tractor wouldn't start and when I tried all I heard was a big spark because the grease hadn't been squeezed out enough. Ended up cleaning everything up with brake clean.
Think twice, speak once.
Re: How to use dielectric grease ? [Re: ST2008] #5157470 07/11/19 08:07 AM
B
Blueskies123 Offline
B
I too have been confused by this subject. Dielectric grease will prevent good electrical contact if any gets into the posts or wires. While it may seal out shorts it should not get into the wires so I only use it on my power equipment spark plug boots, NOT the spark plug itself.
I had to clean up several flashlights that went berzerk after using dielectric grease.
Re: How to use dielectric grease ? [Re: Snagglefoot] #5157492 07/11/19 08:29 AM
K
kschachn Offline
K
A common notion but incorrect.Yes dielectric grease as such does not conduct electricity but it doesn't matter. You don't want electricity flowing between gaps in conductors anyway, the grease does not inhibit conduction where metal-to-metal contact occurs. This subject comes up on here from time to time and there are studies you can find which show that using dielectric grease inside a connector does not impede current flow. If the contacts aren't making contact, then you aren't getting current anyway unless it is arcing.
You're not "getting away" with anything. If the connection isn't tight then the presence of grease or no grease isn't going to matter.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: How to use dielectric grease ? [Re: ST2008] #5157496 07/11/19 08:32 AM
SVTCobra Offline
For me dielectric grease is nothing more than a non-conductive (for automotive applications) grease that seals out moisture from electrical connections, preventing corrosion. Since it is non-conductive, if it doesn't squeeze out and ends up in between the connection, then it causes more problems that what it's fixing. That is where I think most of the conflicting information comes from is how successful it works for each individual. This is definitely one of those cases where a little goes a long way.
Re: How to use dielectric grease ? [Re: SVTCobra] #5157500 07/11/19 08:34 AM
K
kschachn Offline
K
Again, if the contacts aren't making contact then that's your real problem, not the dielectric grease. If they are making contact then the grease is not the problem either.
And before someone suggests it, conductive grease is NOT what you want.
1994 BMW 530i, 252K
Re: How to use dielectric grease ? [Re: kschachn] #5157505 07/11/19 08:37 AM
SVTCobra Offline
My experience is my old cable terminals are not the same exact size (larger) as the battery post leading to inconsistencies in how well it makes contact and therefore squeezing the grease out. Before I go and replace my terminals I'll continue using the oil soaked felt pads.
Re: How to use dielectric grease ? [Re: SVTCobra] #5157510 07/11/19 08:39 AM
K
kschachn Offline
K
That could be true. But if they aren't making contact then they aren't making contact. Air is a dielectric as well.
1994 BMW 530i, 252K
Re: How to use dielectric grease ? [Re: ST2008] #5157516 07/11/19 08:43 AM
SVTCobra Offline
It's making good enough contact to work without the grease, hence why I said I don't use it on battery terminals from my post about the tractor.
