Originally Posted by Triple_Se7en
Originally Posted by Lubener
No, I am educated and can read the box which states "synthetic fiber enhanced filter media". If you are unable to read the print on his box photo , maybe you can pay someone to do it for you. Anyway, it was a great value for $1.99 at the time. Much better than the junky ecores of today which I would never use.
The early Ecores that you have a liking to, were garbage. Media would come unglued. Cages had enlarged holes that accepted loose media, allowing dispersion thru the engine. ADBVs would squak right from the get-go. Lastly, even the gasket would develop leaks early-on.
So your education has it backwards. The Ecores of today are only a dollar more than 15 years ago and are 3X better than the early versions..
Unless you have pics of your filter failures, your experiences are irrelevent. I never had a problem with the old ones. You can stick with your plastic caged filters if you are so hung up on them.
