Mityvac exploded!
Suburban Washington DC
Actually, imploded to be accurate. Was sucking out the milkshake from the top of coolant reservoir when I heard a big boom. Don't these things have a relief valve or something to prevent this?
[Linked Image]
Originally Posted by KrisZ
I don't see the manual pump handle, is that the model where you can use compressed air to create vacuum? If so then it looks like you went overboard with vacuum on it.
This.
This.
This is my thought as well.
...is that the model where you can use compressed air to create vacuum? If so then it looks like you went overboard with vacuum on it.
There's a compressed air hose w/ connection on the ground next to it.
I took the hose off after it blew. There is only so much vacuum it can produce and that shouldn't be more than the tank can handle.
I'd say its just old hard plastic for whatever reason.
get a new one and continue on..
I have the 6gal harbor freight one and its really decent.
