Originally Posted by njohnson
Originally Posted by RDY4WAR
I don't think it's entirely hogwash, but I think the reason he stated is hogwash. In the racing industry, there's a gradual shift away from HDEO due to frothing and anti-wear concerns. I know with our engines, we saw a 320% increase in iron wear (196 ppm vs 47 ppm) with HDEO compared to the specific racing oil we are now using. That's rather substantial. The engines were torn down after discovering this (2 seasons with HDEO) and 5 of the 16 cam lobes failed micrometer testing with >200 microns loss in lobe height. These engines are solid roller lifter, not flat tappet, although they are approaching 1,000 lbs spring pressure at max lift, over .900" lift, and turning 9500 rpm. A scenario way outside of any API testing parameter.
For a classic car with a stock rebuilt flat tappet engine making div>
Could you tell us the brand of the HDEO? Just curious, not that the results would be different with a different brand, it is a case of the HDEO not being the best oil in the application. We are buying HDEO for our tractors on the farm. I started using them in some of our gas engines as well, OPE and older SUV and truck. It seems to be working well.
Same result with Rotella T4 15w-40 and Delvac 15w-40. It's just not the best oil for the application. A lot of people in the classic car and racing circle started using it for the ZDDP content, but are now learning there's much more to oil than just ZDDP.
