2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
Castrol GTX 20w50
by VQLT - 01/27/20 09:33 AM
Mevotech Terrain Tought ttx?
by buck91 - 01/27/20 08:54 AM
House electric questions
by supton - 01/27/20 08:37 AM
How an automatic transmission works
by supton - 01/27/20 08:08 AM
AC Delco UPF48R and UPF64R $1.50 rebate at Rock Auto
by Snagglefoot - 01/27/20 07:15 AM
Burner718, masstrnsprtcmplx, tampasaint, rdmjone, BigGeo
70537 Registered Users
111 registered members (67ZL1, 55hambone, 330indy, 53' Stude, 1978elcamino, 2011335d, 15 invisible), 3,051 guests, and 20 spiders.
Topics300,638
Posts5,179,975
Members70,537
Page 1 of 15 1 2 15
Is Liquimoly Overrated? #5156725 07/10/19 11:47 AM
A
ad244 Offline OP
A
Hey BITOGers
Ive never seen a oil analysis which really showed an amazing result when using Liquimoly.... Is the stuff overrated especially when you factor in the cost?
Can't most of the same spec's be met with a lot of the Mobil 1 or Castrol offerings?
Re: Is Liquimoly Overrated? [Re: ad244] #5156731 07/10/19 11:55 AM
K
kschachn Offline
K
Originally Posted by ad244
Hey BITOGers
That is most easily determined by looking at the label on the container or the PDS and seeing which ones are, or aren't listed. Oil analysis won't tell you squat in terms of approvals and specs.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Is Liquimoly Overrated? [Re: ad244] #5156740 07/10/19 12:04 PM
T
TiGeo Offline
T
That is the consensus here on several posts on the topic (some mine). I have been using LM on my Golf Sportwagen and it certainly looks fine to me in terms of UOA but I'm sure I can achieve the same results for half the price. I paid ~$65 delivered for my last LM oil change kit from an online Euro-part retailer I like to purchase from that included 6L of oil, a VW filter, and drain plug. I like the convenience and the hate to say it, we all get to spend money on what we want and I like it so I buy it. If going to Walmart and getting M1 or Castrol 0W40 on sale and rebates etc. and getting filters/drain plugs on Amazon is your thing, by all means go with it! I know a lot of folks say the 0W40 oils (for those looking for the typical Euro approvals i.e. VW502.00) are higher-quality than the LM 5W40. This is my last UOA.
2018 VW Atlas SEL 4Motion 3.6 VR6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 TSI Unitronic St2 IS20 - LiquiMoly 5W40 VW filter
2013 Ford Focus SE HB 2.0 Ti-VCT - MC syn-blend 5W20 MC filter
Re: Is Liquimoly Overrated? [Re: ad244] #5156745 07/10/19 12:08 PM
E
edyvw Offline
E
Hey BITOGers
BUT, you are paying those oversized Made in Germany letters? I mean, don't you feel you get AT LEAST 20hp using that oil?
Yes, Mobi1 and Castrol meet all those requirements and are available in Wal mart.
Liqui Moly is OK oil, but it is average in every aspect. They are more focused on marketing than anything. When Group III oils started to make their ways as "synthetic" Liqui Moly immediately switched to group III and by far was the most aggressive in selling it as something beneficial.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Is Liquimoly Overrated? [Re: ad244] #5156769 07/10/19 12:26 PM
B
BMWTurboDzl Offline
B
IMO LM is overpriced relative to the competition.
Motor oil is so inexpensive in the United States so it's difficult for an importer to be competitive.
435i
Re: Is Liquimoly Overrated? [Re: ad244] #5156783 07/10/19 12:41 PM
T
TiGeo Offline
T
I did watch a funny video on YouTube from a Euro tuning shop a while back that was doing a special on ECU flash tunes. In the promo/video they were trying to get folks to do preventative maintenance ahead of the tune at their shop including spark plugs and oil changes (smart). The guy in the video says "get your oil changed with LM, it's higher quality than inferior oils like M1 and Castrol" - hahahahahaha. Hey, whatever sells stuff. Again, I'm a LM user but understand it's not magical or really any better than the other common oils for these approvals.
Re: Is Liquimoly Overrated? [Re: ad244] #5156797 07/10/19 01:08 PM
B
burla Offline
B
So redline 5w30 is known to be a tick killer, no oil like it that I have seen and for those interested we have tested many. One particular case redline wouldn't kill the guys tick, his application was 40 weight, and he added liqui moly mos2 to his redline run and the tick was killed. So overrated, depends on what you are using it for. We do believe this guys issue was piston slap and not lifters as it was a cold thing only, but clearly it worked.
Re: Is Liquimoly Overrated? [Re: burla] #5156803 07/10/19 01:14 PM
B
BMWTurboDzl Offline
B
The customer should pull out all the MOS2 which sank to the bottom of his oil pan and re-sell it.
435i
Re: Is Liquimoly Overrated? [Re: edyvw] #5156804 07/10/19 01:17 PM
T
talest Offline
T
Hey BITOGers
Liqui Moly is OK oil, but it is average in every aspect. They are more focused on marketing than anything. When Group III oils started to make their ways as "synthetic" Liqui Moly Royal Purple immediately switched to group III and by far was the most aggressive in selling it as something beneficial.
Royal Purple
Fixed that for you smile
Royal Purple is presently on shelves at Walmart for like $30 to $40 in 0W-20, 5W-20, 5W-30 and is Group 3, API SN.. Mobil 1 is probably a better oil, Royal Purple is no longer special and there are those that will say it was always hype, now it does not seem to warrant the cost and the Supertech on the shelf is probably as good or better, certainly the premium offerings as M1 and others too...
If Moly is desired get QSUD.......
Quote
LiquiMoly NextGen LOL
Thought it was circulated and held in suspension every time the oil reached operating temperature. Makes the oil look like grease.
Re: Is Liquimoly Overrated? [Re: ad244] #5156805 07/10/19 01:18 PM
dubber09 Offline
I just used half a bottle of Shaeffer's Moly EP in Forte at last oil change and engine starts easier and runs waaaay smoother and quieter since, but took about 100miles to notice the change.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Is Liquimoly Overrated? [Re: talest] #5156810 07/10/19 01:24 PM
E
edyvw Offline
E
Hey BITOGers
Royal Purple
Quote
I am talking about 1990's when HC was a thing in Liqui Moly line up, before coming to US market.
Re: Is Liquimoly Overrated? [Re: ad244] #5156813 07/10/19 01:25 PM
B
buster Offline
B
Yes it is.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Is Liquimoly Overrated? [Re: TiGeo] #5156843 07/10/19 02:31 PM
A
ad244 Offline OP
A
Very interesting thanks for sharing
Very helpful to the nature of this thread
Re: Is Liquimoly Overrated? [Re: ad244] #5156847 07/10/19 02:33 PM
A
ad244 Offline OP
A
5L of 5w-30 for $37
https://www.amazon.com/gp/product/B...;linkId=5667f155b1c80e1b2a4b08c818bfd01a
when compared to a Pennzoil product which is similar
https://www.amazon.com/gp/product/B...;linkId=4d7bb47e7ab0eda9c39bc647da7cb28a
I just dont see why one would spend the extra money
Re: Is Liquimoly Overrated? [Re: BMWTurboDzl] #5156849 07/10/19 02:35 PM
V
vw7674 Offline
V
I was thinking the pistons expanded as the engine heated up & killed the cold piston slap.
But whatever.
Page 1 of 15 1 2 15
