Originally Posted by Dave Sherman
Since there's a mechanical seal at the compressor shaft, it could still ooze tiny amounts of refrigerant over years. It's not like the compressor in your home A/C or refrigerator where all the moving parts are sealed inside the compressor housing. I had a leaky schrader on my last vehicle that would leak; if I unscrewed the dust cap on the low side fitting I could hear a brief hiss. That one did leak down to the point it stopped working completely, and when I discovered the leaky schrader I made sure to screw the cap on tightly after having it recharged. Seemed to fix it, but if I unscrewed the cap it still made a little "psst".
I do remember it being explained to me, that, as an AC system in a car is running, there has to be a tiny bit of leakage by design or it will not work properly. Further, that when the compressor is spinning, there is a tiny bit escaping past the shaft, this may or may not have been the tiny bit being referred to. I understand that it transfers heat out of the cabin and puts it in the engine bay behind the radiator, for a nice air to air transfer of heat helped by the fans that pull air. Where the vents that pull the air from the cabin are, I never did know, of course it different for every car I would think. But while true that if you have to add some or if it stops being cold this indicates a leak, the cars that need to be "topped off" every summer, that should not be.. The better question maybe would be, how long would that leak that is supposed to be there need in order to make the system not work? Or am I wrong here
