I replaced the middle leaf in my leaf spring pack as it had cracked and half of the leaf fell off. I used new u bolts to reassemble everything. This is on a 98 ford ranger. Ford specifies 76 ftlb of torque for the u bolts. I oiled the u bolt threads so i decreased the torque by 20 percent. I tightened the nuts to 60 ftlb. I noticed that the tops of the u bolts are bending outwards. These are 1/2 in grade 5 u bolts. The torque chart that came with the u bolts said that they can be torqued to 96 ftlb. I am just surprised they are bending at 60 ftlb. Is this normal? The old u bolts were straight and not bent.
