Hi all,
First time poster from Australia here. I've read a lot on BITOG and the general consensus (correct me if I am wrong) is that Mobil 1 uses group III oils as it's base stock? However, I've been reading the Mobil (Australia) site, where it mentions this (quote) -
"Mobil 1 is made using the highest grade base stocks - Group IV/V PAO/Esters - combined with proprietary additive packages that deliver far greater protection than competitive full synthetic motor oils. Put simply, Mobil 1 keeps your engine running like new even under the most extreme conditions."
So now, I'm a little confused, is it made with group III or IV/V?
Here's the link to the page in question - https://www.m1oils.com.au/why-mobil-1/unsurpassed-protection/
Thanks in advance
Thanks in advance
