Originally Posted by WhyMe
are they truly sealed and never need a top off? my 2011 honda is not blowing as cold as i like. everyone says they are sealed systems and should never need a top off and if it does it means its got a leak.
So is this true, or do they lose a little over time?
All systems eventually lose gas -some faster than others. In every car I've owned, the AC has functioned well for the first 5-6 years then, needed a 2-3 oz recharge. Back in the days of R22, I learned how to do basic AC system service. On the family cars, I usually do the work myself and have a complete set of hoses/gauges. When I do it now, I need to brush-up on the technique and get a current copy of the pressure/temperature tables.
Any automotive system that needs more than a few ounces of charge probably has a leak that needs to be repaired.
For folks who have no idea what they're doing, it's a risky proposition. If they insist on DIY... if they are working on a weak but functioning system, they should get an electronic scale and put in 1 ounce, test it for a while and add one more ounce. Repeat process until 3 (max 4) ounces have been installed. If it's still not vastly improved after that, take it for service at reputable place -Before blowing the system up to smithereens.
Ray
