Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
96 registered members (alchargo, 2012AccentSE, AdditiveOCD, 1978elcamino, 1WildPig, ad244, 11 invisible), 2,272 guests, and 29 spiders.
Topics291,935
Posts5,013,745
Members68,670
Most Online2,967
Mar 10th, 2019
Page 2 of 3 1 2 3
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5155265
07/09/19 03:54 AM
07/09/19 03:54 AM
California
Direct_Rejection Offline
California
OP surely understands that the 2.7L 4 cylinder engine found in his 1995 Tacoma is the 3RZ FE engine, which does not have oil pressure-controlled variable valve timing.
My 2005 2TR FE and my 2018 2TR FE have been significantly affected in terms of performance and fuel economy by variances in viscosity grade.
Both M1 0W40 and Motul Specific 508.00 509.00 0W20 would likely avoid piston ring coking and excessive valve stem seal wear.
Gokhan notably used M1 0W40 right after replacing the valve stem seals on his Corolla, then switching to TGMO 0W20, and now M1 EP 0W20.
2018 Tacoma 2.7L
EDGE HM 0W20
@ 131k miles
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5155346
07/09/19 07:13 AM
07/09/19 07:13 AM
Ice Box of the Nation
Doublehaul Offline OP
Anybody care to chime in about oil condition? Getting pretty tired of “warranty theory 101” around here.
How do the knowledgeable posters feel the lube performed?
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Direct_Rejection] #5155347
07/09/19 07:15 AM
07/09/19 07:15 AM
I have two of these...ones a v6. no diff in fuel economy between the 40 and 20. No difference in sound either fwiw. Both spin over 3k in normal highway driving...both are dog slow
Mobil 1 0w40
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: kschachn] #5155376
07/09/19 08:06 AM
07/09/19 08:06 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Originally Posted by kschachn
Which again states that the viscosity is recommended. If 0W-40 damages the engine then it’s a problem, yes. But it will not.
Therefore whether or not it is recommended it will not void the warranty.
Wrong!
The last sentence in that Bulletin states the warranty will not be covered. They are recommending we do not void their warranty.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Triple_Se7en] #5155403
07/09/19 08:35 AM
07/09/19 08:35 AM
CO
JLTD Offline
JLTD  Offline
CO
Wrong!
Well, if we are going to lawyer this to death, it could be said that the document does not say what country the oil specification must be from to maintain warranty, so if the oil used could be found in specification anywhere in the world it would be ok to use....which also backs up the owner's manual which does state a thicker oil may be required for protection.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Triple_Se7en] #5155425
07/09/19 08:50 AM
07/09/19 08:50 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Wrong!
It says if engine damage occurs because of the oil then it will not be covered under warranty. Obviously engine damage is not occurring per the posted UOA (and would not due to an oil such as Mobil 1 0W-40). And, this is a Toyota under consideration not a Hyundai.
if you have a plausible and technical scenario where using Mobil 1 0W-40 will result in damage his engine then let's hear it. That's one of the best oils on the planet.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: dblshock] #5155442
07/09/19 09:00 AM
07/09/19 09:00 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Originally Posted by Doublehaul
2019 Tacoma 2.7l I4. Lifted and on 32in LT Tires. This is mostly highway usage with sustained RPMs in 3500 range for hours on end. The factory fill was dumped with about 100 miles on the unit and replaced with m1 0w40fs and run until 10k. This is M1 0w40fs after its second 10k run. Oil filters are Super Tech with no top off added.
TBN looks good. Hoping some of the numbers are high due to break in. TBN looks money and it looks like the m1 held up great. You guys think i have a winner here?
Thank you for the report.
I will offer a counterpoint FWIW.
I have driven two different 2TR FE's for a grand total of 870k miles.
Local deliveries of small parcels, light pallets and such has been on the front burner for me. Like you, I put a lot of freeway miles on my Taco.
TBN does not concern me as much as you, with all the freeway miles. TBN is not linear. My personal preference is a carefully selected lower viscosity oil.
Watch for the proverbial piston ring coking and valve stem seal wear as you approach 200k miles, with the accompanying oil consumption.
Enjoy your sled, Sir !
He'll likely avoid those issues using 0W40.
Yepp, agree, i can bet my 2 cents on that.
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Starman2112] #5155528
07/09/19 10:23 AM
07/09/19 10:23 AM
California
Ed_Flecko Online content
Ed_Flecko  Online Content
California
Bottom line, it’s foolish to put your warranty at risk because you think you know more than the engineers who designed the vehicle.
That's how I feel. I'm one of those people who follow the manufacturers recommendations "to the letter" while the vehicle is under warranty. Why take the risk of giving the service department (and/or the manufacturer) an easy way to refuse service if / when you ever have a problem by using a product other than what is specifically called for?
I see forums just littered with people bitterly complaining that the dealer won't work on their vehicle after they've altered / changed the vehicle, used different fluids than what were explicitly called for in the owner's manual, etc., etc.
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: dblshock] #5155818
07/09/19 03:34 PM
07/09/19 03:34 PM
East Tennessee
Starman2112 Offline
Starman2112  Offline
East Tennessee
right, I'll run 5/30 in the bitter cold otherwise give me the heavy luxury grades in warm weather, like a man.
Talk about uninformed statements...
2018 Toyota Tacoma SR5 / Mobil 1 AFE 0W-20 / OEM filter
2010 Toyota Camry LE / Mobil 1 AFE 0W-20 / OEM filter
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5155876
07/09/19 04:53 PM
07/09/19 04:53 PM
Oil condition...anyone?
Mobil 1 0w40
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5155910
07/09/19 05:42 PM
07/09/19 05:42 PM
Southern Oregon, USA
sdude2k2000 Offline
sdude2k2000  Offline
Here’s directly from Toyota manual. Pay specific attention to the last sentence.
Quote
Engine oil selection
“Toyota Genuine Motor Oil” is used in your Toyota vehicle. Use Toyota approved “Toyota Genuine Motor Oil” or equivalent to satisfy the following grade and viscosity.
Oil grade: ILSAC GF-5 multigrade engine oil
Recommended viscosity: SAE 0W-20
SAE 0W-20 is the best choice for good fuel economy and good starting in cold weather.
If SAE 0W-20 is not available, SAE 5W-20 oil may be used. However, it must be replaced with SAE 0W-20 at the next oil change.
Oil viscosity (0W-20 is explained here as an example):
• The 0W in 0W-20 indicates the characteristic of the oil which allows cold
startability. Oils with a lower value before the W allow for easier starting
of the engine in cold weather.
• The 20 in 0W-20 indicates the viscosity characteristic of the oil when the
oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
'08 Ford Fusion SEL 3.0L
'15 Toyota Prius 1.8L
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5155986
07/09/19 07:04 PM
07/09/19 07:04 PM
CO
JLTD Offline
JLTD  Offline
CO
Yup....all CAFE until the red lettering, which is the part the engineers wrote and insisted upon! LOL
Using AMSOIL
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5156057
07/09/19 08:26 PM
07/09/19 08:26 PM
Hence 0w40
Mobil 1 0w40
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5156088
07/09/19 08:51 PM
07/09/19 08:51 PM
sdude2k2000 Offline
sdude2k2000  Offline
Hence 0w40
cheers
Good stuff. I ran M1 0w40 once in my Prius - engine ran like a top... just effected my MPG more than I'd like (more due to the way the Prius engine works, probably negligible difference in your application). Congrats on the truck btw... love a good Tacoma.
Re: 19 Tacoma 2.7 M1 0w40 10k oci [Re: Doublehaul] #5156108
07/09/19 09:05 PM
07/09/19 09:05 PM
Fl
3311 Offline
3311  Offline
Fl
I think you have a winner with the 0w-40! I would continue to use it. You have evidence to back up its performance.
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
Page 2 of 3 1 2 3
