I purchased my first lawn mower about a year ago. It is a Honda self propelled model with a 21" deck. I recently noticed when rising off the mower after use that the blades were developing holes on the bottom blade (2 blade system) on either side. I noticed the holes getting larger after each use, and last week when mowing the mower started vibrating and not cutting like it used to.
I never mow over roots or anything that would damage the blades, so I find it odd that they would be so worn after only one year of use. I went ahead and replaced the blades with another set of Honda OEM blades and did the first oil change. I used Mobil 1 10w30.
My question is, is it typical to have to replaced blades after only 1 year? Maybe the 2 blade system on these just use thinner blades so they wear out sooner? At any rate, I can live with $27 once a year for new blades, I just thought they would have a bit more life.
