Well, I went to have my safety inspect done last week and found my odometer has stopped working. I always check it when scheduling my OCI and it was fine just a few months ago. I used to reset it after filling up the tank to gauge my fuel mileage and I'm wondering if that caused something to snap inside. FYI, my Lesabre is a 1999 and does not have digital odometer. Does anyone know if this is set up like some other 1990's cars I've seen people on youtube demonstrate repairs for? On some vehicles, it looks like their is a plastic gear (crappy quality plastic gear apparently) and this gear is part of a plastic gear set that is turned as the speedometer runs so that the odometer registers in tandem with it. I am going to need this repaired before the inspection is approved and for obvious need for mileage recording. I know the original owner and I'm absolutely sure that it was never tampered with. For what little I have found online, it looks like the dash panels come off to allow the removal of the dash cluster and then you either replace the cluster or you repair this mystical gear set. If anyone has any experience with this on this generation of GM cars (W Body and older), share anything you believe may be helpful. Sigh.....Sure wish I was going to spend money on something more fun than this but such is life.
