Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Dishwasher makes crackling noise
by jayjr1105 - 02/19/20 05:33 PM
what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
24Carat, Antherzoll, mmahaley, Butterfly, TorchHypnosis
70752 Registered Users
128 registered members (53' Stude, 4WD, 55hambone, 69GTX, 92saturnsl2, 01rangerxl, 14 invisible), 2,142 guests, and 21 spiders.
Topics301,667
Posts5,200,245
Members70,752
2005 Toyota Highlander humming noise. #5154071 07/07/19 04:52 PM
dja4260 Offline OP
The front drivers side of this vehicle has a hum to it. The faster I go, the louder the hum is. The noise doesn’t go away if the vehicle is in neutral. It doesn’t matter if I’m turning or tracking straight. It’s a consistent hum.
Is there a way to diagnosis if it’s a wheel bearing or something else.
89k, 3.3L V6
Thoughts?
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154080 07/07/19 05:00 PM
newtoncd8 Offline
Likely a wheel bearing. Ours made a noise that would increase with speed.
12 Jeep GC, 04 Lexus RX330, 77 MG-B
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154082 07/07/19 05:00 PM
J
JMJNet Offline
J
You can check Youtube on how to check those parts (wheel bearing and CV joint) ???
It is somewhat universal regardless of cars make and model.
It is relatively easy to do with a floor jack.
  • 2017 Toyota Sienna
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154096 07/07/19 05:15 PM
W
Warstud Offline
W
Expressway On and Off ramps are a good place to test a Wheel Bearing. Pick one that has sharp left and right turns. If the humming sound goes away while turning right.....your right bearing is bad.
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154109 07/07/19 05:34 PM
M
mclasser Offline
M
Wheel bearings can sometimes make noise but have no play and vice versa.
To rule out a possible bad tire, rotate it to the back and see if the sound moves.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 2005 Toyota Highlander humming noise. [Re: mclasser] #5154133 07/07/19 06:34 PM
dja4260 Offline OP
Okay, I did just that and the noise was the same. I put the vehicle on jack stands and spun both the front wheels. The one in question was much louder...
I'm heading over to rockauto right now...
1997 HD Sportster
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154238 07/07/19 09:00 PM
O
Oro_O Offline
O
Here are some useful ways to test:
Grab the tire at 3 and 9 and rock. See if there's play. If so, could be tie rod or bearings.
Grab tire at 6 and 12 and rock. if play, could be ball joints and bearings.
Spin wheel with one hand, grasp a coil of the spring. bad bearing will pass on vibration most of the time.
After some city driving, get out and feel wheel hub(s). A hot one can indicate a bad bearing or stuck caliper bolts/piston (dragging brakes).
Between all these test, you can get a pretty good idea of problem.
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154286 07/07/19 10:37 PM
R
Rolla07 Offline
R
Id say its quite certainly a bad wheel bearing.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: 2005 Toyota Highlander humming noise. [Re: dja4260] #5154497 07/08/19 08:03 AM
M
meep Offline
M
Good diagnostics. Agree, wheel bearing.
2018 F150
2015 crv (wifey!)
