Now don't judge, but bought a 28oz can of 410a off ebay. Hooked up my gauges, which don't have the pressure/temp values for 410a, but they do accurately measure pressure, right?
Found a disgusting amount of cottonwood junk in the condenser. Seemed beforehand like the fan was blowing well, but I was amazed at how much was packed in there. Spent an hour taking the cabinet apart and vacuuming it up. Put it back together, hooked up the gauges, stuck a thermometer along the vapor line under the insulation.
High side pressure was stable at around 275. Low side about 110. The system maintained these pressures pretty evenly while adding all 28 oz in the can over 45 minutes. Ambient temp was about 73. Vent temp is now 59. Vapor line temp is way up there at about 65.
Please don't fry me. I'm assuming that I overcharged the system. But I'm guessing that the compressor is weak - the high side should be higher and the low side lower.
Thoughts?
Thoughts?
