Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
16 registered members (4WD, AnthemBassMan, GemStater, GumbyJarvis, E365, blufeb95, 4 invisible), 1,003 guests, and 38 spiders.
Topics305,959
Posts5,283,650
Members71,545
Used GC/bearing grease on ball joints #5152964 07/06/19 10:31 AM
O
OCDriver Offline OP
O
I foolishly listened to my old man telling me "oh yeah, that's strong stuff, just use it" when I borrowed his grease gun. Turns out it contains wheel bearing grease (this stuff, to be exact). I used it to grease my end links and outer tie rod ends. I'm replacing the links and one of the tie rod ends anyway, so I'm not worried about those.
What potential problems could this cause? Is it possible to remove it from the grease jacket? Can I just pump in the correct type of grease to push out the wrong stuff?
Re: Used GC/bearing grease on ball joints [Re: OCDriver] #5152980 07/06/19 10:53 AM
danez_yoda Offline
Using very different types of grease in the same boot will give you lower performance thanhaving the same type, the grease could be fine but it mat be contaminated by a different base from tye original grease. that said if you pumped until the new grease came out s little of the old was left you are probably good to go.
Re: Used GC/bearing grease on ball joints [Re: OCDriver] #5153022 07/06/19 11:44 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
You used a grease that is aluminum based. Chances are your links had a lithium based grease in there. It is likely the two greases are not compatible. Are the boots an open design? Can you flush out the old grease by pumping a lot of new grease through?
Re: Used GC/bearing grease on ball joints [Re: OCDriver] #5153061 07/06/19 12:43 PM
Rat407 Offline
No issues at all. I would be more concerned with not being able to get them greased. Seeing that you can they will be just fine.
2002 Silverado 5.3 5w-20 AMSOIL
Re: Used GC/bearing grease on ball joints [Re: OCDriver] #5153063 07/06/19 12:47 PM
Dave9 Offline
It's usually hit or miss on a very simple mechanism, whether you can flush old hardened grease out or the new grease just finds a path past it.
I would get some of the (wrong) grease and confirm it dissolves in gasoline, take the tie rod end off, pop the boot off (if it can be done without damage which it may not) and agitate it in a tube of gasoline while wearing nitrile gloves to get ALL grease out, then shake out excess gas, let dry, re-grease.
However, if one of your tie rod ends is shot, odds are the other one has enough wear that I'd just replace it too, unless for some reason it is very expensive with no good aftermarket alternative.
I suppose that if you have no confidence you can get the wheel toe-in correct after removal for cleaning or replacement, this might be a reason to leave it in place, pop the tie rod end stud out of the knuckle, take the grease nipple off, liberally spray brake cleaner in, work the joint around to loosen the grease, then repeat spraying and working the joint a few more times, THEN re-grease. Once you get all the old grease out, you might find it is looser than you thought and end up replacing it anyway.
Re: Used GC/bearing grease on ball joints [Re: danez_yoda] #5153071 07/06/19 01:06 PM
A
atikovi Offline
A
What are the chances the place you take your car now for a lube job will use the same grease as the place you used the last time? Similar scenario here, and you could argue wheel bearing grease is heavier duty than chassis grease. No more harm than adding a quart of different brand oil to your engine.
Re: Used GC/bearing grease on ball joints [Re: OCDriver] #5153316 07/06/19 07:27 PM
T
Trav Offline
T
If the previous grease was a commonly used Lithium complex then there should be no issue with compatibility. [Linked Image]
