I have a 94 ford ranger with a nonfunctioning ac compressor. This is because the connector to the compressor does not get voltage. Im assuming that would be because there is a ground somewhere along the way that is rerouting it. I was wondering if there is a way to directly wire it to the battery with a toggle switch, is this a dangerous method to give it power. I need the rest of the electrical system to work more than i need the a/c but if there is an easy way to get it working again it would go with that. Whatre some suggestions?
