06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
107 registered members (10WSmuckers, 50jeffrey, Alfred_B, 928, apollo18, alchargo, 8 invisible), 2,848 guests, and 66 spiders.
Topics305,906
Posts5,282,552
Members71,535
2019 Honda Pilot OCI and Oil Choice #5151685 07/04/19 10:42 PM
K
klt1986 Offline OP
K
Wife and I bought a 2019 Honda Pilot EX-L and it now has 3,400 miles on it. The maintenance minder is still at 70% oil life left. I'm guessing with the driving she does, the maintenance minder will show 15% just short of 10k miles....this is what our CR-V did.
I'm contemplating dumping the factory fill oil and filter around 5k miles. If my memory is correct, this is what I did on her CR-V. Any opinions on whether or not to run the factory fill until the maintenance minder drops to 15% or change it half way through?
Finally, the local dealer gave me my first 2 oil changes free and they use Castrol 0w20. I'm sure it is a bulk oil but any thoughts on it?
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151721 07/04/19 11:58 PM
G
gregk24 Offline
G
You will typically hear two opinions on this subject. Run factory fill to 15% as Honda uses a special break in oil, or dump early to remove break in material. Maybe 7500 miles would be a good compromise?
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 2019 Honda Pilot OCI and Oil Choice [Re: gregk24] #5151845 07/05/19 06:42 AM
K
klt1986 Offline OP
K
Not a bad idea running to 7500 miles. I was actually hoping the MM would be about 40-50% at the current mileage but it is almost identical to what her CR-V was.
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151854 07/05/19 06:50 AM
P
parshisa Offline
P
On my wife’s 2016 Exl i chnaged FF at around 4K. After that 4-5K OCI with different 0w20 - good UOA on all of them with really no difference. Not using any oil and piston slap on cold is still there
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151859 07/05/19 06:55 AM
T
TiGeo Offline
T
What does the Honda owner's manual say on this subject? Any particular info w/r to break-in and the factory fill? I would just do what it calls for. 7500 is such a good number to go with b/c it works with tire rotations.
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly 5W40 VW filter+Ceratec/MoS2
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151874 07/05/19 07:05 AM
W
WagonWheel Offline
W
Honda says leave it for full OCI or down to 15% on the MM.
More importantly is to check it periodically for oil consumption during first OCI. Then head over to Piloteers and read about disabling the VCM grin
2003 Honda Accord 2.4L 5AT - 153k miles
2006 Honda Odyssey 3.5L EX-L 127k miles (S-VCM)
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151885 07/05/19 07:31 AM
E
Eddddd Offline
E
Honda does use a “break in” oil and recommends the factory-fill oil remain in the engine until the first scheduled maintenance interval to ensure proper break in. Now there will be a lot of opinions about changing the “break in” oil early but I say follow what Honda recommends. I have owned several Hondas and currently have the Accord with the same 3.5 V6. I kept the break in oil until the MM told me it was time to change and use the MM to let me know when an oil change is due. I have done oil analysis and the oil still shows good and could have went past what the MM recommends. There were VCM issues in the past with the 3.5 but that has been resolved with current V6s. I say use the free oil changes but make sure they use 0W20 synthetic like the Castrol and they don’t try to sneak in a 5W20 dino or blend. Also, make sure you use top tier gas. When I say top tier gas, I do not mean octane rating. Top tier gas is gas that has additional detergents that exceeds EPA recommendations. There is a website that you can find certified gas stations that sell top tier gas. Exxon and Shell are two popular gas stations that sell top tier gas. Using top tier gas really helps keeping the engine clean, especially with Honda’s VCM.
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151890 07/05/19 07:41 AM
T
TiGeo Offline
T
Our '06 Ody had the VCM and it was the cause of multiple very expensive replacement motor mounts and lots of vibration - terrible design (assume current is much better) to save a tiny bit of gas.
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151894 07/05/19 07:45 AM
T
Triple_Se7en Offline
T
What was the age & miles on the former CRV? Why did you trade it-in?
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151895 07/05/19 07:47 AM
Bud Offline
I follow the MM on my Pilot and use Mobil 1 0w20 AFE. Have since new. Don't know if the VCM issues have really been resolved or not, so I use the VCM Muzzler.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: 2019 Honda Pilot OCI and Oil Choice [Re: Eddddd] #5151911 07/05/19 08:06 AM
K
klt1986 Offline OP
K
Did you encounter piston slap from the start? I have not noticed any with ours.
Good question. I will check tonight as I have really not thought about it too much since it is new.
So far the oil level has remained at the full mark.
Do you recall the mileage when the MM got to 15%? I have instructed the wife to use Exxon/Mobil, Shell, or BP as they are all top tier gas stations in our area. We have run a couple tanks of Kroger gas through it. That was due to having fuel points worth $1 off per gallon. Getting 35 gallons of gas at $1.32 or so per gallon is worth it once a month. I have read that some Kroger gas is top tier and others stations it is not....depends on who the supplier is.
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151922 07/05/19 08:16 AM
P
parshisa Offline
P
yeah, just on cold engine. it is unaudible at idle rpm but very noticeable at 1000-1200 rpm range. I checked another brand new pilot dealership had on the lot and it sounded the same. check your and see if it does the same lol
Re: 2019 Honda Pilot OCI and Oil Choice [Re: Triple_Se7en] #5151928 07/05/19 08:20 AM
K
klt1986 Offline OP
K
2008 Honda CR-V EX with just under 200k miles. Thought about keeping it but that would have been 5 vehicles plus a work vehicle in our driveway. Dealer offered a very fair trade in price after we had agreed upon a price for the Pilot. They were close enough that it was not worth the headache of dealing with the tire kickers.
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151936 07/05/19 08:31 AM
U
UncleDave Offline
U
Honda does not use special "break in" oil. The break in oil is moly rich from the assembly lube and they recommend it stay in the full OCI.
I kept my Ridgeline break in oil in to about 7500 and changed the filter as well even though honda calls for it to stay in another OCI.
I slapped a filter mag on at about 500 miles and when I removed it I cut the filter open open - it was filled with all kinds of detritus Im happy to have gotten out of the system.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2019 Honda Pilot OCI and Oil Choice [Re: klt1986] #5151945 07/05/19 08:44 AM
T
T
I know the feeling. We used to keep three vehicles - then both daughters had their own vehicle. That made (5) also. This went-on for 3-4 years.
It was a pain sometimes, because our driveway is narrow and no turnaround in it. So at least (2) were always on the street..... sometimes 4.....lol
