- Joined
- Nov 29, 2009
- Messages
- 7,268
I want to have a dipstick cover on my outdrive heli coiled. I stripped it out by accident. The issue is just it has a small oil drain hole the is drilled in from the side and that will be covered up by the heli-coil. The dipstick that threads into the cover covers about half the 1/4 of the hole. Opinions?
Can you cut the heli coil so it's shorter and doesn't cover the hole?
