Originally Posted by David1
I listen to the magic mechanic show and he is always talking about how the new thinner oils cause tremendous wear on engines. He says it's not the manufacturer's fault. That engine will get like 4 to 10 miles extra out of tank of gas. using thinner oil . So car companies are being forced to tell people to use these super-thin oils that cant takes the heat and if you live in a very hot area it's even worse.
So I guess my 2010 Fusion making it to 274,000 miles on (mostly) 5w-20 oil was due to some kind of witchcraft? Oh yeah, and this all happened IN PHOENIX, one of the hottest cities in the US, consistently. So much of the above is complete nonsense.
He says 0W30 is perfect...
Wait, 0W-30? Is that even a thing? I've never even seen a single bottle in that weight. And I wonder what would make that acceptable, but not a 0w-20 or 5w-20, which are both pretty close in viscosity at operating temp.
He also says if you use the 0w16 your engine will be worn out at 100K miles. Compared if you used 0W30 or 5W30 and get 300K or even 400k and yes he likes Amsoil. He is dead set against 0w20 and this new 0w16 is just crazy according to the magic mechanic
So what do you all think about this?
I think this 'Magic Mechanic', whoever he is, is horribly misinformed and/or stuck in the past, and flat-out wrong.. at least when it comes to modern engines. I suppose if he's referring to something from the 80's or 90's, he might be right, but then again, he'd also be completely irrelevant, as there were no oils in the specs available at that time in 0w-20 or 5w-20, AFAIK.
