I listen to the magic mechanic show and he is always talking about how the new thinner oils cause tremendous wear on engines. He says it's not the manufacturer's fault. That engine will get like 4 to 10 miles extra out of tank of gas. using thinner oil . So car companies are being forced to tell people to use these super-thin oils that cant takes the heat and if you live in a very hot area it's even worse.
He says 0W30 is perfect...
He also says if you use the 0w16 your engine will be worn out at 100K miles. Compared if you used 0W30 or 5W30 and get 300K or even 400k and yes he likes Amsoil. He is dead set against 0w20 and this new 0w16 is just crazy according to the magic mechanic
So what do you all think about this?
