Originally Posted by tiger862
Originally Posted by TN Tracker
I gave the 5w20 to my daughter for her Expedition. Has anyone read about the theory that we are using oil that is too slick and the rollers are just sliding on the cam causing flat spots?
There is alot of theories out there. I would never say a fact that a theory is true or false cause few theories make sense. I will say Chrysler recommends conventional oil and without documentation hard to say however how many are out there abused on conventional without cam failures. I studied this since rocker failure as it's common with 3.6 caused by needle bearings falling out. If you believe posters they write synthetic at 5k and had failure after 100k and hardly ever conventional 5w20 with OLM. Something to think about. I put synthetic 5w20 in Grand Caravan cause I don't put many miles but I am second guessing it and probably will go back to conventional. Havoline recommends conventional oil for my 2018 3.6 as well as Chrysler.
If Synthetic 5w20 was the exact issue that's causing catastrophic failure I believe you would see alot more Grand Cherokees, Rams, Chargers, and Challengers on the side of the road.
The engines been around almost 20 years. 5w20 has been the spec for almost half of those years.
It's just the luck of the draw, much like oil filters, not everyone is gonna fail, but at the end of the day, the ones that do get blasted on the internet.
5w30 is in the OM, for towing it's okay. I doubt that using it over a 5w20 is gonna make a world of difference while not towing.
Keep idle times low is the best piece of advice period.
