Post Your Latest Coolant Change.
96 ram 3500
5.9 v8
Pulled heads due to stuck valves and severely bent pushrods, machine shop found heads were also cracked, so head and head gasket replacement
Out: dirty green crap, water, qmi cooling system flush, more water
In: 60/40 Starfire universal green, water, qmi cooling system conditioner
2008 Toyota Aurion, 167750km, drain and fill. Out: 4.5l of Radicool SF-O in the engine for the last couple of years and 35000km, which replaced the factory fill when the water pump went. In: Nulon Red Premium Long Life Premix. First time when I used the Lisle spill free funnel kit, what a brilliant tool that is!
06 f150
5.4 v8
Thermostat replacement and cooling system flush
Out: unknown green coolant, qmi cooling system flush
In: 60/40 Starfire universal green and water, qmi cooling system conditioner
1988 Bolens 1502 diesel tractor
Out - traditional green coolant
In - Peak FleetCharge 60/40
Yes - I flushed the system out too.
09 Chevy traverse
3.6 v6
Water pump replacement
Out: unknown green coolant, water, qmi cooling system flush
In: 70/30 Napa universal green and water, qmi cooling system conditioner
217 Kia Rio 1.6L Gamma
Mileage @ change: 74320
Mileage on Coolant: 74320
Out: 3qts OEM (only three came out the petcock... not low in system, just surprised..)
In: 3qts Valvoline Asian (PHOAT)
No sebacic acid; states sodium benzoate on back only. I think the sodium benzoate is the only carboxylic acid in these, so I'll probably just do this small swap every 30k
2004 Jeep Grand Cherokee 4.7 V8, Zerex G-05. I drained it, changed the upper and lower radiator hoses, then filled it. It has about 104k miles on it. Not bad for such an old Jeep. It runs great.
12 Buick enclave
3.6 v6
Out: probably original dexcool, water, qmi cooling system flush
Hi
Had to have the radiator changed on my WK Grand Cherokee 3.0crd with OM642.
Garage i used is a Mercedes specialist so they used the blue G48 coolant mb325.0 to replace whatever was in.
Thanks.
2007 Honda Accord (radiator drain)
Out: I assume OEM Honda blue (no records)
In: 3.75 quarts of 50/50 Peak Global.
Waiting for someone to tell me my car is going to grenade.....
Hi
Apologies for posting this in wrong section.
If a moderator should see this please move to 'post your latest coolant change'.
