This seems like as good of a place as any to ask about DIY/home improvement stuff, and thought I'd see if anyone can offer some advice on what I'm dealing with as far as this toilet.
As some background, this townhouse was built in ~2006, and I've been living here since August of 2011. This is the main toilet I use(I live alone) and it hasn't missed beat until just a few weeks ago. It's a Mansfield-brand toilet, and I don't THINK it has ever been worked on-it at least hasn't in the last 9 years, and all the parts I looked at were branded Mansfield.
A few weeks ago, two things happened at the same time. First, the handle broke. Shortly after that, it started leaking from the tank into the bowl pretty seriously(I can see water running down the sides of the bowl when the tank is full).
I replaced the handle with a generic brand part(don't think that should affect anything-it looked similar to the one I removed) and replaced the seal on the flush valve. I used a genuine Mansfield brand part on the latter, especially as I've had issues with generic ones in the past on a different toilet. I bought two seals the same day from the same hardware store, and the one that installed on a different toilet is working perfectly fine.
After replacing the seal, the fill valve started acting up(wouldn't open enough to fill the toilet), so I replaced that.
Now that that's done, I can't get the flush valve to seal adequately. It will seal enough to fill the tank, but it will drain down enough that the fill valve cycles back on every couple of minutes. If I turn the water off, the tank will empty(into the bowl) in ~10 minutes.
I'm at my whits end on this-I can't think of what else to replace on it unless I change out the entire flush valve, but that's also a tank-off job and am not sure about tackling that one myself. Can anyone else advise on what to try before I swallow my pride and call a plumber?
