Pulled a boo-boo. I was mixing oil for my boat. The mix ratio for the boat is 50:1. I dumped enough oil for 8 gallons of gas into the tank and filled it, just guessing how much gas it would take. It only took five gallons. I'm guessing that it is a ten gallon tank if memory serves me. So, I have five gallons with the correct 50:1 ratio and five gallons with enough oil for eight gallons of gas. First question, what is my new fuel ratio? Second question, if I drain this fuel and use it in my automobiles, one ounce/5 gal gas (640:1 ratio?), how much fuel should I mix with a gallon of drained boat fuel to get an acceptable/non-harmful mix?
Or perhaps easier, how much more fuel would I have to add to have a correct 50:1 ratio?
