5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
27 registered members (dbias, carlprop, deoxy4, blufeb95, 928, bworley, 1 invisible), 1,049 guests, and 16 spiders.
Topics301,965
Posts5,206,604
Members70,808
Shift Flare on brand new rebuild + MaxLife #5146770 06/28/19 08:59 PM
R
roachslayer Offline OP
R
I just put in a newly rebuilt 4L60e in my 06 Chevy Suburban - all kinds of excellent updates, including Borg Warner clutches, aluminum pistons, updated TCC regulator valve, and much more. Filled with MaxLife ATF, and it has a Hayden 679 cooler (bypassing the radiator).
... and yet I'm getting a p0894 "transmission component slipping" on the very first test drive, with noticeable RPM rev when upshifting. WHAT. THE. [email protected]#$ ?
My understanding is that flare is usually caused by incorrect fluid, low fluid, high fluid level, wrong pressure (blocked cooler), or worn out transmission. Clearly not the last item, and the fluid level is perfect. That leaves only "incorrect fluid", or it is a pressure/flow issue.
I am completely puzzled on BOTH fronts here:
1) MaxLife is supposedly great stuff, many 4L60E owners running it with great results.
2) Hayden 679 cooler is also run by 4L60E owners, no issues.
Sure, the Hayden cooler is not advertised as LPD (Low Pressure Drop) like the TruCool has, but still... could this be the problem? Or is full synth really an issue here? The shop that did the rebuild says they use plain Dex III, which is lame considering you can't even get that anymore! I could painstakingly change the MaxLife out for Dex VI... but I seriously do not see WHY I should need to do that, as it is listed as Dex III and Dex VI compatible.
So confused, and very frustrated given the thousands invested here!
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146787 06/28/19 09:20 PM
TheLoneRanger Offline
How far did you drive it on the test? It's possible that there's air bubbles in the torque converter or valve body causing the slipping.
I'd run it through all the gears including reverse, and see if the problem resolves itself...
Some days you eat the bear, some days the bear eats you.....
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146790 06/28/19 09:22 PM
spasm3 Offline
Did you fill the converter with fluid before installing?
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146815 06/28/19 10:43 PM
J
Jetsfan421 Offline
J
Could be a bad transmission. It is a rebuild, which are normally great, but bad ones can happen. Maxlife should be fine in this application, and when running a rebuilt or remanufactured transmission I would install one oz per qt of lubegard red. Rebuilt is not as good as remanufactured.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146827 06/28/19 11:36 PM
clinebarger Offline
Maxlife works great in 4L60E's......In fact, 4L60E/700R4 transmissions are NOT in the slightest picky about ATF!!!!
If you have flares on EVERY upshift & setting Component Slip codes......The line pressure needs to be checked like......YESTERDAY!!!!
DO NOT drive the truck 'til Line Pressure Rise is verified!
This is not a Torque Converter filling or Air Bubble problem & most certainly NOT a ATF problem ASSUMING the level is correct....It takes @13 quarts to fill a dry 300mm converter 4L60E with a empty/flushed Rad cooler + stock auxiliary.
The cooler circuit has a internal bypass.....Even if the cooler/s were completely blocked, The trans would behave normally 'til it overheated to the point ATF vented.
2001 Chevy Camaro L92/4L80E
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146838 06/29/19 12:59 AM
R
R
Thanks for the ideas folks. I will check line pressure next. @clinebarger I am guessing this means you are suspecting a flaw in the rebuild somewhere?
FYI, it locks perfectly fine in gear, it shifts ok when going easy, but when pushing a bit hard (not WOT, but still pretty heavy acceleration) is when the flare will be noticeable.
I didn't install the torque converter but will ask my tech about his install procedure - he should know to fill with fluid first. As for how far was my test drive, it was about a mile down the street.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146842 06/29/19 01:24 AM
clinebarger Offline
Filling the converter is NOT necessary. The pump will fill the converter through the Regulator Valve.
Without a "charged" converter.....The vehicle will not move.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146847 06/29/19 01:33 AM
clinebarger Offline
Even more reason to check Line Rise!
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5146964 06/29/19 08:10 AM
SubieRubyRoo Offline
It's been a long time since I've had a GM trans under my care, so I will definitely defer to clinebarger on what you should be checking. But I routinely use MaxLife ATF, and considering it is a Dexron fluid from the word go, will concur that the fluid is not the root cause of your problems. Unless you want to be installing another trans... I'd check and correct the line pressure ASAP. Low line pressure will quickly lunch those 4L60s!
De omnibus dubitandum.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5149988 07/03/19 03:46 AM
I
i6pwr Offline
I
When are you getting the flare? All shifts or certain ones?
The only time I experienced flare on my 4L60E was around 160K when one of the check balls was pushing through the separator plate, would flare at the 2-3 shift.
New plate and all is still good at 291K.
Granted this was a pressure loss like others are suggesting, hard to say where it's happening at. But definitely get this sorted ASAP, doesn't take much to smoke the clutches.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5157965 07/11/19 03:26 PM
R
R
Thank you all for the comments.
The flare mysteriously disappeared, apparently.
The shop that did the rebuild has my Suburban and said they could not detect a flare (after a test drive). So I came to the shop and rode with them, taking turns driving. Indeed, the flare is gone, at least for the 1-2 and 2-3 shift. I will have to test the 3-4 shift on the freeway later.
How?
When I first posted this, it was maybe 5 miles of test driving after the newly rebuilt trans. Now it's got over 40 on it. The only 2 possibilities I could come up with are:
  • Air was in the system, now purged?
  • Computer had to "relearn" the tolerances of this transmission vs the prior?
This shop told me it takes 500 miles for the computer to completely adjust itself for this. Forgive me if I don't believe in computer relearning... just seems that makes Chevy look way too smart. But the fact is... the flare has subsided after driving it more.
Next Steps:
I will be clearing OBDII and checking for new thrown codes and any human detectable flares and slipping again. Open to other ideas too.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5158109 07/11/19 06:21 PM
stanlee Offline
9 times out of 10 if you have flare on the first drive you have a low fluid level. Fluid has to be checked after the fluid is hot so fluid should have been checked AFTER the first drive (shop should have made the first drive and actually tested their work before you got it). I bet all they did was check/add fluid.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5158170 07/11/19 08:02 PM
R
R
@stanlee thanks, good to know. I remember checking it before and after I detected the flare, while hot, but not after driving several more miles to the shop... so if it was a purging issue of fluid not getting into some place it was needed right away, that could make sense.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5192121 08/20/19 01:36 PM
R
R
Sadly, this is still unresolved. The transmission shop looked up the p0894 code and of all the resolutions for it, they saw the ECU/PCU was listed. So naturally, being the only thing on the list that is NOT the transmission itself, they pointed at my ECU to blame so as to avoid any responsibility. I obliged, and got a new ECU, and... yep, same codes, same issues. So I am no taking it back to them with the new computer and they will need to take the transmission out and give me a new one. Ugh.
For my own sanity and curiosity, take a look below and tell me what you think. I'd like to understand what is happening so that I can address it with YET ANOTHER REBUILD.
The transmission shifts so smooth you can't even tell it happen. UNTIL, that is, it gets up to temp! Once up to temp (like after 20 min freeway driving), if I immediately go back to stop-n-go in city traffic, I can then feel it "buck" or kick me when shifting from 1-2 or 2-3. But even in town, it goes back to smooth as glass perfect shifting after the trans cools down (no longer on freeway). So it only has an issue at higher temp. What might that mean? FYI: I have a Hayden 697 fin and plate cooler on this, bypassing the stock radiator cooler - the Hayden is big enough to cool a huge rig, so this should be plenty.
Re: Shift Flare on brand new rebuild + MaxLife [Re: roachslayer] #5192136 08/20/19 01:56 PM
MolaKule Offline
Global Moderator
Global Moderator
Did the shop put the MaxLife ATF fluid in or did you?
Did the shop road test this transmission until the fluid was up to operating temperature?
Did they use the same valvebody from the old transmission? Sometime the valvebodies have to have minor mods when upgrading components.
if the fluid level is correct (checked when very hot), then the problem seems to me to be one of pressures vs. temp. It could be the pump has leakage.
The rebuild shop needs to check pressures when hot and correct this situation.
I'm a Student Pilot. Frightening, isn't it?
