Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
91 registered members (AC1DD, 4WD, 1WildPig, Aero540T, 2009Caraman, 90crvtec, 8 invisible), 1,919 guests, and 31 spiders.
Topics300,413
Posts5,175,252
Members70,497
90915-YZZD3 particle count - ISO code 24/23/15 #5144137 06/25/19 09:12 PM
newtoncd8 Online Content OP
OP Online Content
After seeing DuckRyders ISO code 24/23/15 for both the Fram Ultra and the HAMP filter, I sent in for a UOA from our RX330 -- I got back the same ISO code.
Oil had 5,659 miles, RX330 has 245,000+, Oil was PPHM 5W30, Filter was (oversized) 90915-YZZD3.
Intend to get a TG and try it at some point.
For those interested, full UOA posted to the UOA section.
[Linked Image]
12 Jeep GC, 04 Lexus RX330, 77 MG-B
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5144141 06/25/19 09:15 PM
Z
ZeeOSix Offline
Z
Blackstone's PC test machine seems to be broken, lol.
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5144152 06/25/19 09:33 PM
G
geeman789 Offline
G
Remarkably consistent ... or not.
The small particle ranges are pretty wide though. 24 equals 80 000 to 160 000 , 23 equals 40 000 to 80 000 ...
So MAYBE they are accurate ?
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: ZeeOSix] #5144865 06/26/19 03:27 PM
DuckRyder Offline
Or might it be that things don’t work the way we suspect they do... ?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: DuckRyder] #5145136 06/26/19 08:27 PM
Z
ZeeOSix Offline
Z
It's a bit perplexing, because some of the PCs posted by members here seem to follow the rated ISO filter efficiency pretty well as you've seen by some of my plots of that data. To me, that doesn't seem to just be a coincidence. Something is going on, but hard to know what at this point.
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: DuckRyder] #5145196 06/26/19 10:17 PM
B
bbhero Online Content
Online Content
B
I suspect that you may well be correct here...
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: bbhero] #5145203 06/26/19 10:44 PM
Z
ZeeOSix Offline
Z
There's no reason beyond somw anomaly that a PC shouldn't be better with a more efficient filter. All the SAE papers that study filtration show a very good correlation between PC oil cleanliness and filter efficiency.
Some of the PC data off this site that I've plotted shows that expected correlation - even the Microguard showed better PC below the 15μ point like you'd expect. When filters rated at 50% @ 20μ or 99% @ 40μ have the same PC as filters rated at 99% @ 20μ then something is skewing the correlation. Maybe something is amiss at Blackstone. How is that test equipment calibrated, and how often?
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: ZeeOSix] #5145323 06/27/19 06:12 AM
DuckRyder Offline
Call them or e-mail them and ask they will tell you.
I don’t think Blackstone is what is askew... I agree that something might be askew and if so it would be interesting to figure out what it is. It also could be that a lab created correlation does not necessarily translate into a real world correlation.
Robert
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: DuckRyder] #5145658 06/27/19 02:02 PM
Z
ZeeOSix Offline
Z
I see no reason why it wouldn't. It doesn't make sense that two filters on opposite ends of the filtering efficiency spectrum would give the same oil PC/cleanliness measurement. You've seen the SAE study plots in controlled tests I've posted before, and the oil PC data followed the filter rated efficiency very well. We may never know what the real reason is.
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5145879 06/27/19 06:32 PM
OP Online Content
I am new to this PC and don't see very much to compare the results to, but what are the chances that the 2011 Amsoil filter test is not accurate (or no longer accurate) and the Toyota OEM filter is better than most people report? Or am I not tracking correctly on the ISO code I got?
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5145905 06/27/19 07:02 PM
P
Pinoak Offline
P
I've seen plenty of pc that show filters rated highly effective bay SAE not look better than a typical cellulose filter. It's probably got to do with multiple passes.
I no longer believe there is much benefit to spending extra on so called highly efficient filters.
High capacity filters can, ofcourse, be worth the extra cost but only if they are used for extended hours or miles. If I buy a M1 oil filter rated for 20k miles and I keep it in use for 20k mile or the equivalent in hours then that's money well spent. If a guy has an application that doesn't allow him to safely go the full distance or he just don't want to then to then it was a bad purchase and benefits him nothing.
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5145943 06/27/19 07:56 PM
Z
ZeeOSix Offline
Z
It's possible the Toyota Denso filter is better than 51% @ 20u per the independent ISO 4548-12 testing Amsoil published back in 2011.
But here is some PC data I posted from the UOA forum on BITOG, and this is how I'd expect the data to plot out showing a good correlation between the ISO 4548-12 rated efficiency and the PC data.
My theory on why some filters show a bad PC (DuckRyder's XG7317) vs their efficiency rating is because they are probably leaking somewhere past the media due to manufacturing issues (not design), or the methodology of the oil collection and/or test accuracy and repeatability is bad - that's the only things that makes sense. Other Ultras and similar high efficiency filters have shown good PC correlation with their rated efficiency. Open the uploaded PDF file for a better view of the plots.
Attached PDF document
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5145948 06/27/19 08:14 PM
OP Online Content
If I were to take a sample from the current YZZD3 filter I have on our RX330 at 2,500 miles, swap to a Tough Guard and run it for 2,500 miles, send in a sample and get a PC on each, that should be a good apples-to-apples comparison?
The other option is to remove the current filter (it only has about 500 miles on it), install a TG and run it for about 5,000 miles (to make an apples-to-apples for the test I posted above) and then get a PC.
Trying to decide which to implement.
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5145972 06/27/19 08:52 PM
Z
ZeeOSix Offline
Z
I would think running the TG for the whole 5000 miles on the same engine would be a better comparison. Swapping to a TG now with only 500 miles on the oil and running it to 5000 miles shouldn't skew the results.
How are you taking the UOA samples?
Re: 90915-YZZD3 particle count - ISO code 24/23/15 [Re: newtoncd8] #5146138 06/28/19 04:53 AM
DuckRyder Offline
Unless the filter design has changed since the test I sort of doubt it.
My problem with this (which you well know) is that if you only plot the data that supports your hypothesis the data will always support your hypothesis.
We’ve been over all this as well. There were no signs of defects in the filter. No one mentioned seeing any either when it was posted. I believe it would be MUCH more likely that sampling methodology would create a low PC vs high. I did confirming follow up PC on both the Ultra and Hamp. My data is clean, it is at least as good as any other data here. Still, it is only 2 filters on one car, so it only tells us how those particular filters performed on that car.
In order to prove or disprove any correlation we would need much more data collected using a consistent procedure.
When I originally embarked on the PC counts part of what I wanted to try to figure out was if filters really do get more efficient as miles pass, which seems to be a common belief. You could actually do both, run your Toyota filter for 2500 miles take a sample, change the filter to a TG and sample it at 2500 then again at 5000. The oil should have no problem going 7500.
After going back and looking at your UOA, I notice the Lexus has high mileage, as does the Civic. This is another thing thats been in the back of my head,,, The filter can’t catch what the engine doesn’t produce. It may be that PC counts from newer engines are going to be inherently lower than those from higher mileage engines... All variable that need to be considered.
Robert
