I’m looking at synthetic gear oil for my F150 rear differential, and I see the following flash point data (from manufacturer’s product bulletins):
AMSOIL Severe Gear Synthetic 75W-140 ----------------> 210C
Mobil 1 Synthetic Gear Lubricant LS 75W-140 ----------> 207C
Pennzoil Synthetic 75W-140 ------------------------------> 188C
Valvoline SynPower Full Synthetic Gear Oil 75W-140 ---> 173C
Data for other parameters (what there is of it) seems relatively comparable between the products.
I generally hold Valvoline products in high regard. Is the low flash point on the Valvoline a reason to not consider it? What is the general opinion in BITOG-land of Valvoline’s gear oils, and which of these (or something else) would you specify?
