Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
84 registered members (AC1DD, alcyon, aba4430, Aero540T, 2009Caraman, 7 invisible), 2,057 guests, and 21 spiders.
Topics301,931
Posts5,205,687
Members70,801
The Mysterious Mopar SAE 5W-20? #5144147 06/25/19 09:24 PM
J
John344 Offline OP
J
Does anyone know which oil is the Mopar SAE 5W-20 (Middle East Version)? I know that it’s provided by SHELL since SHELL have a factory for oils in Oman, but which SHELL is it? The label doesn’t mention anything about the type of oil used if it’s Synthetic or Blend or Conventional oil? The dealer claims that it’s a fully Synthetic oil 100% but why the bottle doesn’t mention anything about it? Isn’t it supposed to be marketing features to write down fully synthetic oil like other brands do?
[Linked Image]
[Linked Image]
I tried to contact SHELL to confirm which type of oil do they supply for Mopar but couldn’t’ get any respond.
I found that SHELL Helix Ultra has some similar approvals and it’s fully Synthetic but they are no proof that it’s the same oil.
This is why I’m thinking of switching to Liqy-Moly 5W-20 SPECIAL TEC AA
[Linked Image]
[Linked Image]
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144164 06/25/19 10:08 PM
7
71Chevyguy Offline
7
Liqui Moly is a much better oil than Mopar any day. I would choose that over it if it was my vehicle.
18 Focus 1.0 Mobil1 5w20 / Mobil1 filter
98 Buick LeSabre Defy 10w30 / Fram Ultra 3387a
85 Skylark 2.5
71 Nova 250
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144176 06/25/19 10:57 PM
M
Mad_Hatter Offline
M
Deleted
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144184 06/25/19 11:09 PM
M
Mad_Hatter Offline
M
I you hadn't already figured it out, the Mopar parts# is on the label (68218890UA)... like you, I couldn't find anything on the net after a couple mins of looking, stating whether it was conventional or synthetic. I did find this SDS 👇from Mopar with that part# but I'm not an expert on reading these things, especially oil related one's. Maybe there is/isn't anything in there that helps you...
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.kwparts.com/media/1718/68218891gb_eng.pdf&ved=2ahUKEwi0gr7QrIbjAhVIrp4KHeCTBxwQFjAAegQIARAB&usg=AOvVaw1QEJvrgS7t1LOVyjDkAaoA
Looks like Chrysler Canada makes both a dino and full syn 5w20...i have no clue if or how this relates to your oil. Just thought I'd share what I additionally found. (I could not locate anything in the API db for Chrysler middle east, maybe I was doing it wrong?)
[Linked Image]
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144194 06/25/19 11:18 PM
R
rubberchicken Offline
R
Given the high temps in your area, would a 5w30 or even heavier oil be a good alternative ?
Re: The Mysterious Mopar SAE 5W-20? [Re: 71Chevyguy] #5144196 06/25/19 11:29 PM
sloinker Offline
You do realize that Mopar doesn't actually produce their own oils. They are pretty heavily involved with Pennzoil right now but who knows who produced that particular quart featured. I think it isn't synthetic or it would say so.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: The Mysterious Mopar SAE 5W-20? [Re: rubberchicken] #5144207 06/25/19 11:55 PM
O
OilUzer Offline
O
I would stay away from x20 in your area. I would use a good 10Wx30 or 10Wx40 or even higher ... Something with higher hths. 5Wx30 is the lowest I go if I have to.
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144210 06/25/19 11:57 PM
07hemi Offline
https://www.google.com/url?q=https://www.dealers-mopar.com/resources/pdf/chemical/chemical-catalog.pdf&sa=U&ved=2ahUKEwjArJieuobjAhXDZc0KHR4ID3MQFjAOegQIBBAB&usg=AOvVaw24ASksqkgKIZyR8eZjzQpc
Looks like anything that's labeled Max pro + is full synthetic. Max pro doesn't specify, so I'm guess it's either conventional or synthetic blend
2016 Dodge Dart GT 2.4 QSUD 5W20 (mine)
2015 Chrysler 200 AWD 3.6 Phillips 66 shield choice 5w20 (wife's)
2007 Dodge Ram 1500 5.7 QSUD 5W20 (mine)
Re: The Mysterious Mopar SAE 5W-20? [Re: Mad_Hatter] #5144211 06/25/19 11:58 PM
J
John344 Offline OP
J
[Linked Image]
Exactly, I tried searching online and contacting them but I didn't get any information or answer. Not even a SPEC sheet available online.
Re: The Mysterious Mopar SAE 5W-20? [Re: rubberchicken] #5144213 06/26/19 12:00 AM
J
John344 Offline OP
J
I would love to use a thicker oil but the manual state clearly that the 0w-20 is used for all temps. The car is jeep GC.
Re: The Mysterious Mopar SAE 5W-20? [Re: sloinker] #5144214 06/26/19 12:06 AM
J
John344 Offline OP
J
Yeah, this is what I'm thinking too if it's Synthetic they would write it all over the bottle, but the dealer is telling me that it is and they use it for a long time and it's set for 10,000 KM intervals.
Re: The Mysterious Mopar SAE 5W-20? [Re: 07hemi] #5144216 06/26/19 12:09 AM
J
John344 Offline OP
J
e
I'm doubting it's convetial but why would they allow it to stay in your car for long intervarls? every 10,000 KM? The Middle East is considered a Severe climate and usually, have special services especially for the oil because it's hot and dusty.
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144223 06/26/19 12:29 AM
Skippy722 Online Happy
Online Happy
You have the v6 then? Assuming you’re not driving it like you stole it, 0w20 will be perfectly fine in it. V6 has a liquid to liquid oil cooler.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: The Mysterious Mopar SAE 5W-20? [Re: Skippy722] #5144232 06/26/19 12:52 AM
J
John344 Offline OP
J
Yes, indeed it's a 2018 V6 and the oil temps usually around 90-100 Celsius often 95 Celsius. I drive it very normally and I don't tow.
Re: The Mysterious Mopar SAE 5W-20? [Re: John344] #5144234 06/26/19 01:18 AM
Online Happy
I’ve got 2 of those v6’s, though yours is the upgraded version (PSU/PUG) of the Pentastar. Hottest I’ve ever seen my oil was 212F, 100C, on the van. My 300 likes to sit around 170F-185F, ~76C-85C. Hottest I’ve seen the 300 was 200F, 93C.
But I run 0w20 in both of them, and I drive them a little harder than most.
