Howdy fellow oilers:
Just came home from "Fred's." They have a brand of tranny fluid for a dollar a quart. Around these parts, even "wally world's" tranny fluid is $1.22.
Fred's brand is called "Streett" (yes, with two "t's").
Label says:
Dexron - III Mercon
Approved for GM "H" specification
Back label says:
Streett: Quality Lubricants Since 1884
Streett Dexron III/Mercon ATF is a quality multipurpose fluid with improved oxidation resistance and allows higher temperature operations. Recommended for electronically controlled automatic transmissions meeting General Motors "H" specifications (GM-10055), Ford, and Chrysler.
. . . . . (talks about Chrysler cars) . . . .
General Motor Corp. Registration No: H-36182
Ford Motor Company Registration No.: M050102
Detroit Diesel Allison: C-3, C-4
Catepillar: TO-2
The address on the bottom of the back label reads
J.D. Streett & Co., Inc
Maryland Heights, Mo 63043.
I had planned on using this in my '96 Chevy truck. It has a four speed automatic tranny.
Do you guys think this stuff will do the job even though it's 0.20 cents cheaper than the Supertech stuff? (I did buy one bottle and the fluid is red). Right now, that's all I know.
Thanks a million in advance -
Glenn.
Label says:
Dexron - III Mercon
Back label says:
Catepillar: TO-2
Glenn.
