Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
Is bar and chain oil hard on rubber?
by jqgz - 11/17/19 12:53 PM
TSC - Mobil Delvac $10.99
by Greg L - 11/17/19 12:42 PM
Wifi Thermostats
by FA_WRX - 11/17/19 10:33 AM
Test drove a few trucks. Ram Pentstar V6?
by dja4260 - 11/17/19 10:15 AM
2010 Corolla LE Opinions
by maverickfhs - 11/17/19 10:06 AM
XTR74, 2009Caraman, redmonkey01, gnouhp, tiblow
69896 Registered Users
129 registered members (2009Caraman, 4WD, 330indy, 2004tdigls, 69GTX, 17 invisible), 2,372 guests, and 23 spiders.
Topics297,558
Posts5,117,996
Members69,896
Most Online3,589
Nov 2nd, 2019
2019 Yamaha FX Cruiser HO #5144166 06/25/19 10:14 PM
J
jtwrace Offline OP
J
Hello all.
I just bought one and decided to change the oil and filter early at 5 hrs. They recommend 10 hrs but an early change before a long ride is what I was after. I'll do another change after it and swap to synthetic from the Yamalube 4W 10W-40 that is recommended.
I'm thinking of just going directly to the Amsoil 10W-40 Marine. Thoughts?
Located in FL
"Science is not a democracy"-Earl Geddes Ph.D.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5144191 06/25/19 11:17 PM
R
rubberchicken Offline
R
That is a good oil for the Waverunner. Check out your owners manual and see if a 15w40 is also acceptable- there are tons of good marine 4 stroke oils in that range.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5144390 06/26/19 07:20 AM
T
thastinger Offline
T
My 2 Kawasaki STX skies aren't supercharged but they are 4 cylinder 4 strokes. I just run Mobil 1 Euro 0-40 in them. Your manual should tell you that several different weights of oil is acceptable depending on temp.
Some of the new ones have cats on them so pay attention to oil selection if that bothers you as some of the marine oils have higher levels of zinc because most boat engine don't have cats but live at high RPMs most of the time.
Re: 2019 Yamaha FX Cruiser HO [Re: rubberchicken] #5145035 06/26/19 06:47 PM
J
jtwrace Offline OP
J
It is acceptable. Which would you suggest?
Re: 2019 Yamaha FX Cruiser HO [Re: thastinger] #5145037 06/26/19 06:49 PM
J
jtwrace Offline OP
J
Funny you mention that, I seriously thought about that as I used to run that in my Porsche. I even thought about 15W-50 M1. Just not sure if the "Marine" spec really means anything. Does it? Does it really resist corrosion etc better than a M1 or similar? 5qt jug of M1 from Walmart is pretty hard to beat cost wise. I'm certainly not opposed to Amsoil as I really think it's great oil, just don't have a need to waste money however.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5146066 06/27/19 11:49 PM
R
R
Amsoil recommends this oil- https://www.amsoil.com/shop/by-prod...rmula-4-stroke-marine-oil/?code=WCFQT-EA
I would probably use this or the Amsoil 10w40 product code AMO
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5146303 06/28/19 09:27 AM
A
Arctic388 Offline
A
AMSOIL Marine would be a great oil. Personally I am running Rotella T6 5w40 in my Seadoo GTI's and I have been an AMSOIL "dealer" since 2005. Rotella is a great oil for PWC's
2015 Sierra Z71
1999 Malibu
1996 Tahoe 4x4
2015 Seadoo GTI SE 155 Limited
2017 Seadoo GTI SE 130
1998 Yamaha XL760
1996 Seadoo GTX
2005 Yamaha Grizzly 660
https://www.youtube.com/user/Arctic388/videos
Re: 2019 Yamaha FX Cruiser HO [Re: rubberchicken] #5146485 06/28/19 01:32 PM
J
jtwrace Offline OP
J
That's what I got, thanks.
Re: 2019 Yamaha FX Cruiser HO [Re: Arctic388] #5146487 06/28/19 01:34 PM
J
jtwrace Offline OP
J
I seriously thought about using that. My only hesitation is that a diesel engine doesn't have the high RPM that a gas engine and in this case our PWC will see. Cavitation is a serious concern, however, I'm sure any decent slippery stuff will work just fine.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5163640 07/17/19 03:55 PM
T
thastinger Offline
T
Everyone who owns one, and cares anything about it, changes the oil at the end of the season as part of the winterization process. I ran M1 15/50 in the years before 0-40 Euro was available, never had any oil related issues...they are both 04s.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5165706 07/19/19 06:09 PM
J
jtwrace Offline OP
J
I ran the Yamahlube for the first 10 hrs. Changed it both times at 5 hrs and it was black. Have Amsoil Marine in it now and with 18 hrs on the oil it's still clear. Amazing how good this stuff really is. And it has been seeing much higher sustained RPM's than the Yamahalube too.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5165833 07/19/19 08:17 PM
P
philipp10 Offline
P
You do realize you are only changing about 1/2 the oil on each change....right? You can only pull out about 2.3 qts out of the 4.5 available in the motor.
Re: 2019 Yamaha FX Cruiser HO [Re: philipp10] #5166035 07/20/19 06:04 AM
J
jtwrace Offline OP
J
I'm able to get a measured 3.8 qts out every time.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5166240 07/20/19 09:52 AM
P
philipp10 Offline
P
I may be mistaken. I will need to look into this as I am changing mine this fall.
Re: 2019 Yamaha FX Cruiser HO [Re: jtwrace] #5223624 09/27/19 02:50 AM
M
MarshPirate Offline
M
I've been using 5W-40 T-6 in my 2 2015 Yamaha FX Cruiser SHO WR's since new. I've been happy with it.
